Originally Posted by grandam1979
It looks like the intake is still far away from the front cover did you already have the other bolts tight? The threads on that bolt look very bad hopefully it wasn’t like that before you installed it?
I admit they were bad. Some had been flattened somehow, I ran them through an old tap to clean them up. The beginning of the bolt went in fine, then it snapped around 20 ft-lbs, i'd guess. I should've stopped when things got tight.
