Originally Posted by Big Bear
The 67 rear spring reduces size at top . 64-66 has a large top spring pocket.
This^^^. The '66-'67 rear axle is an inch wider than the '65, but the frames are otherwise dimensionally the same. Since your car is a LeMans, it came with a manual trans or the 2 speed auto, so the trans crossmember mounts should be in the same location as the '65 frame. Go for it. It's a straight bolt-up-and-go deal.
