The squeegee Phoenix sends is pretty stiff plastic. I sprayed both stripe back side and vehicle with the water/ soap solution, laid down stripe and started in the middle. Took squeegee and worked the solution out the edges. Can't see if there is any bubbles left until you pull off outer layer 3 hours later which is now too late. Going to a professional today and ask if they can do any better. It doesn't look horrible but I'd like it to lay perfectly flat and smooth.
I did use a needle and a hair dryer which can get rid of alot of it but not the smaller ones.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
