Today I wanted to finalize the clutch hydraulics and confirm that everything will work. So I bled the clutch. I know that there are numerous methods out there, as well as all kinds of tools. My favorite solo bleeding method is still the "clear bottle with a tube" method.
Remember that bleeding hydraulics is not about pressure. There is no need to pump the pedal as hard and fast as you can. The goal is to displace air and replace it with fluid. Gently moving fluid through the system does just that, without aerating the fluid.
Once the hydraulics were free of air I was able to press on the clutch pedal to see what was happening at the bearing. The nice thing about doing this outside of the car is that I am able to look through the clutch fork hole and see exactly what is happening inside the bellhousing. I discovered that the fittings on the side of the throw out bearing were touching the clutch pressure plate. The LS7 clutch spring fingers sit a good ways down when the pressure place is bolted to the flywheel. So the solution was to press the bearing off the piston and put some shims behind it. This way there is more space between the body of the bearing and the face of the bearing. Hard to imagine what I am talking about.
Here is the bearing at rest, with the shims already installed.
Here is the bearing at full release.
The pedal is firmer than I expected, but the release is super smooth. So much better than the mechanical bearing with the z-bar. I would recommend this mod to anyone, regardless of engine choice.
Andrew
