I looked far and wide for a replacement power window switch after the the factory switch crapped out on my 76 TA. As far as I can tell no one sells repros and used ones are rare. If anyone has a line on switches I'd be happy to know as well (I was able to open up the switch and repair the internals, so I'm good for now . . .).
I assume you have seen the threads about rewiring the power windows with relays? The factory set up sends all the power for the windows through the switch, which wears out the switch and reduces power available to the window motor. This may be less of a concern with all new wiring.
Are you replacing the door latch while you're in there? I recently replaced my driver's side latch and it's a huge improvement.
