Originally Posted by Trevor78
The door mirrors? You can get various replacement glass. Get the thicker type if you do, I had a set sent once and they were thin and with jagged edge. Also, you can swap internals on RH side but only on the left with the remote cable of it has the large clearance hole in the stalk. The small hole version is assembled around pre-painted parts.
The cabin rear view mirror would be trickier with the high beam deflector tab, and the vinyl trim that needs to stretch if brittle. I haven't really tried it, had a repro that had come apart from rough shipping. It was never really right after that and tossed. Starting to delaminate or get spots under the glass?
You have an eBay account of same name? Was looking at something and saw name the other night.
yes it seems to be a bit tricky to do the rear view mirror
if you need any thing let me know
