So i made a block off plate for the front of the turbo and put 25 psi too it. I already found a good sized leak at the IAC block off plate. Enough so my compressor counldnt keep up with it. It is a small compressor though. Once the silicone drys ill continue on with the test. I cant help to wonder if this was always leaking or it was the new problem that brought me to this thread.. Hopefully i can get this on the intake side . I forgot to say i also found a crack in the up pipe to the turbo yesterday i fixed that but still have things going on i guess..
My Half AN Injun.....
