^^What he said^^.
Also, I am not 100% because mine is long gone but I think there is a vent from the canister that runs a rubber line to the bowl vent on the carb if your car has EEC. That line going back to the tank would connect to one of the lines coming off of the standoff pipe located behind the rear seat. The other three lines from the standoff go to the three vents on the fuel tank.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
