Originally Posted by 66sprint6
Hey, rohrt. What model car are those covers for? I don't recognize them. They look to be well made.
The covers are from PUI for the tempest custom. They make the baseline covers as well.
A few more. They attach with a pin pushed in from the back through the hinge.
Note that the spindle has only a push nut and theres also a grey plastic washer with a step in it.
Thanks for the pictures!
I'm so confused now. They are not what I thought the stock covers look like, but they are what my new covers look like.
In a couple of my pics above you can see just a bit of what was left of what I thought was a factory hinge cover. It looked like a vinyl sock that went over the hinge.
So if that is a plastic step washer that must be the same as the window crank washer.
Any clue where to source that pin that holds the cover on?
So the hinge pin doesn't stick through the cover? I was about to drill a hole through it. Glad I didn't. I will have to do some fitting and figure it all out.
