Originally Posted by giles
I’ll see if I can find a good diagram and post later. Fuel supply and return lines run up the right side of the car. There are three evap lines from the tank that run to the vapor separator behind the seat. Then the vapor line to canister runs in a steel line bundled with the rear brake line up the left side of the car. Rubber hose from near the master cylinder to another steel line under the rad support over to the right side of the rad support where the canister sits.
Thank you for the reply.Starting to figure it out.
