adjusting caster
So I need my memory refreshed......on an "A" body....
If I want to add positive caster without messing up anything else, removing a shim from the front bolt and adding it to the rear bolt does the trick, right?
Also, any idea what the relationship of the shim thickness and the change in caster is, if the above is true?
George
