View Single Post
Old 05-21-2016, 10:16 AM
SD455DJ SD455DJ is offline
Default '71 455 HO GT-37 Journey Begins
Finally got a chance to take a look at the GT-37 I bought from Mike Robbins last year during the coldest February on record, so its been hibernating since then. Put it up on the lift to give it a good visual survey and found it to be really solid. The only bad area in the trunk floor where the original owner kept an open bag of salt that spilled and did what it does best to automotive sheet metal. The floors, quarters, fenders, core support, doors are great shape. It does need the usual lower rear window metal repair.
The motor is the numbers matching original as are the no-date heads. I will need to find another 7041267 carb and RA exhaust manifolds. The intake and crossover are proper too.
Dennis
