Originally Posted by Scarebird
Rick: on your tilt column. does the turn signal shut off after completing a left turn?
Yes. That worked correctly.
However, all was not 100% with this column as delivered.
1. The key buzzer switch and clip were MIA. NOS parts were sourced at the cost of $40. Key buzzer now works.
2. The cancelling cam was a cheap replacement, and was not produced with the groove casted into the end of it to retain the horn wire assembly. A NOS cam was purchased at the cost of $25.
3. The lock plate plastic cover was not included. I was able to carefully remove it from my original column.
Now for the positives:
1. The finish was superb. This goes for all of the exposed metal parts and the satin black finish.
2. Tilt function is tight, and no noises
All in all, it was better to spend the $400+$65 for this one that take a chance on a $200 as pulled column.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
