A slightly longer screw? Or, drill & tap to a larger screw size and install a threaded rod the same material as the main body (or aluminum), and re-drill and tap to the correct screw size.
I do this occasionally on Rochester 2G's.
BONESTOCK GOATS
'99 Bonneville SE Sedan
