The upper grille pieces on every '61 I've looked at are more of a semi-gloss, which is about the same as the Krylon paint I mentioned earlier - the 'dull' in the name refers more to the color than it's level of gloss. Anyway, it's just a thought. You could buy a can and try it out on a sample piece of metal to see what you think, and then add a coat of clear over the top to make it shinier if necessary.
