View Single Post
  #96
Old 07-29-2015, 10:36 PM
Originally Posted by indiangiver 68 View Post
the data plate reads like this
ST 72 23537 A 00781 BDY
TR 272 A 5118 4 65 A PNT
09B 11 011668 180126
The weird thing in the last line after the 09B
the 11 is stamped and with a much bigger
and different font.
Hope this helps.
Mike
Thanks for that good info Mike.
What I'm loosely referring to as a body number is really more of a job number.
It follows the build from start to finish and is listed on the Bsheet as well as trim tag.
011668 on your 09B vs. 269517 on an 04D example.
18 0126 would also be listed on Bsheet.
18 is supposed to be the build sequence for that day or shift.
0126 supposedly the body buck carrier jig number.
The 04D example has number 74 0665.
00781 is your actual Lemans Hdtp Body #
04D is # 19326
A51 is bucket seats
18 might be Console
4 might be Vinyl Top
The stamped 11 , idunno
11 is also a code for White Paint, but can't think of anything right off hand that would need to be cut in with white paint on your car.
It meant something to somebody though.
And your car had a lot of White parts.
04D car had no vinyl top, no 4, and no stamped numbers.
Yours again :
Quezal Gold:
ST 72 - 23537 A 19326 BDY
TR 273 A5118 53 53 PNT
04D 269517 740655
