View Single Post
Old 11-12-2007, 09:55 PM
Lightbulb It's a Chevy six
Originally Posted by scotzz
bigponts62..............both really nice cars..............I am am partial to the 'vert since it has a 6 cyl like my '64 sedan with 50k miles..............and I know what you mean about running good........where is a good source for parts for these 6 cyl engines?.........I need an exhaust pipe but haven't found a source so I'll probably just have one custom made. Also looking for other minor stuff........
The '64 -'65 Pontiac Tempest 215 six-banger is really a Chevy engine through and through. It has 'PONTIAC' cast into the side of the block, but other than that it's the same as a Chevy 230 six (same family as the low-deck 194/230/250 Chevy, the truck 292 has a taller block) except for the bore size.
The Pontiac 215 has a 3.750" bore, the 230 has a 3.875" bore, both have a 3.25" stroke crankshaft. Carb, air cleaner, cam, distributor, fuel pump, oil filter, etc. are all the same as a Chevy.
You can bet that if a '64 -'65 Chevelle six-cylinder exhaust system is available, it will fit.
It's really easy to find parts for.
