Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Head Ccs
If building a roots blower motor from scratch, would you start with 72 or 87 ccs, or does it matter? Would be a pump gas 535, looking to build 900+ hp.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
With a blower, one would want low cr, so the bigger chamber is better.
Agreed, especially with the big cubic inches.
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
Thanks guy. Now I just need about, 10,000 hours of overtime!😀
i think 72cc e heads flow more then 87 cc e heads for example. if theyre ported its still a consideration. if you havent ordered pistons or heads you have options. especially w a 535 youre going to need dished piston with either size head.
i am building a pump gas 505 to eventually turbo on e85 and race gas. i have 87cc e heads and about 10:1 or hopefully slightly less with the piston a skosh in the hole. my friends ls stuff is turboed on e85 in the high 12-13:1 compression
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
The Following User Says Thank You to mysticmissle For This Useful Post: | ||
I have wide ports right now, I don’t want to build a custom intake, and want to get away from the offset roller lifters.
I went with a 400+60 and big cc-455 heads Comp is 7:89"1
It's pump gas friendly and made around 600-hp with a small flat-tappet cam that Scott Brown profiled for me, very simualar to a RAIV cam with a 8-71 blower, very street able and pump gas 3"42 gear and a tight converter from butler. GT |
Under 9:1 is best . I prefer the smaller chamber with dish tops to get it there ... Being its a lager cubic inch it might be a challenge thou.. I have 8:4 and its nice an easy to tune.. The higher you go the smaller the tuning window..
My Half AN Injun..... |
I upgraded the camshaft now I just have to get the car finished that
this blower motor is for. I'm also waiting on a adapter to put on a wenzler intake (shorten of coarse) seen it done on engine masters with a big block chevy and made a 100HP more with back-back runs. I figure with both upgrades hope to see 700HP possibly. GT |
