Old 09-17-2024, 06:30 AM
PLongen PLongen is offline
Default 63 Lemans 4cyl Timing Cover
Has anyone used the aftermarket timing cover from Ames on the 4 cylinder engine?:
https://www.amesperf.com/parts/searc.../?term=+LN482P
Old 09-17-2024, 10:22 AM
tom s tom s is offline
Does your engine have a 8 bolt cover or a 4 bolt?I believe the 4 cyc use a water pump with shorter vains.Tom
Old 09-18-2024, 07:07 AM
mine has a 4 bolt but the casting is very pitted.
Old 09-18-2024, 09:57 AM
You will want to find a 63 4 cyc 8 bolt water pump.Tom
Old 09-18-2024, 12:19 PM
Peter Serio's Avatar
4 or 5 years ago on this forum there was a thread on the 62 & 63 Tempest water pumps and in that thread there were photos of the back sides of pumps side-by-side and there was a specific 4 cyl water pump (for both '62-63 4 bolt and '63 8 bolt timing covers).
Something about the fins on the back of the impeller were different between '63-326 V8 cars and the 4 cyl. Either shorter fins and/or fewer of them.
Peter Serio
Owner, Precision Pontiac
Old 09-20-2024, 08:19 AM
Radman's Avatar
Radman Radman is offline
It took me a while to find this one. Purchased it while I was working on my 62. Check the casting numbers, I think that it will fit your 63. PM me if you want the part. Also are you a member of the Little Indians car club If not, you should join.
ID:	640280   Click image for larger version
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old Yesterday, 05:28 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
V8 pump on a 4cyl isn't a problem. 4 on an 8 will cause heating issues.
