I'm looking at a '68 Firebird that has a dashboard VIN of 223378Nxxxxxx and a cowl tag of 68-22437 LOR.
How can a car be built in both Lordstown and Norwood at the same time? Seems fishy. Anyone encounter this before? |
Whoops. It's not an N in the VIN, it's a U, which was Lordstown, so that's ok.
Still leaves the mismatch between 22337 and 22437. |
the cowl tag will often have the characters of a base model, and the model RPO code will be a couple lines down.
as an example a 1970 Trans Am would have a cowl tag stamping of 22387 (base model Firebird), then two lines below would be the RPO code WS4 - which indicates it was a Trans Am. I think it was done this way because the cars all started as base models, and as they went down the line became associated with a specific order number.
As long as the partial VIN on the Cowl matches the VIN, I would not worry about it. You may be able to see it, without pulling the cowl panel off.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Thread Tools | |
Display Modes | |
