Old 01-21-2024, 01:05 PM
er455 er455 is offline
Default Under dash wiring 79 TA
Hi Guys does anyone know what these 2 connectors went too ? Thanks
Old 01-21-2024, 01:06 PM
They are near the fuse panel area
Old 01-21-2024, 03:50 PM
Wish I could help ya.
Those may actually go to the fuse box, but where I can’t say.
You can look close at the male spades in the fuse box and see where two of them are shinny like there was once one of those connectors on them.
Since the box is labeled you may be able to ring out where at least one of those unplugged ones go, and from there it just a process of elimination for the other one.
The good thing is those two look like they do not have anything to do with the engine cranking or running.
Old 01-21-2024, 04:01 PM
bhill86's Avatar
bhill86 bhill86 is offline
I’m finding the brown wire(s) one listed as accessory feed but I’m admittedly not familiar with its purpose. The green one I’m not finding as of yet and don’t recall seeing it on my 77
1977 Trans Am 400/4speed (swap)
Brian
Old 01-21-2024, 04:09 PM
Default Wiring
Thanks guys , yea the car starts I was just trying to sort the wiring under the dash and found those would just like to know …
Old 01-21-2024, 04:10 PM
Default Wiring
Maybe if I find where they go , I will gain 50 more HP …😂
Old 01-21-2024, 04:24 PM
If you don't have any know problems, probably just wire connectors for some accessory that you don't have? Lots of time the factory loom has the connectors wrapped since they aren't used.
Old 01-21-2024, 04:26 PM
bhill86's Avatar
I can say, with regard to the brown ones, one brown wire comes from the fuse box and goes to that clear connector then from the connector to power the blower motor resistor. The connector may not be used on f bodies. I tried helping another guy on a different forum with an electrical issue and these two wires/connectors your posted came up. I wasn’t able to figure out the green aside from possibly the front speaker but I’m not sure that’s accurate.
Brian
Old 01-21-2024, 05:56 PM
I saw a lt. green for the back-up light and one for a rear window defrost or defog.
Old 01-21-2024, 06:22 PM
bhill86's Avatar
You might be on to something with rear window defogger. That green wire should be near the fuse box I believe.
Brian
Old 01-21-2024, 06:38 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I could be wrong (it's been nearly thirty five years) but I think the green wire is for pulse wipers.
Go fast, see Elvis!
Old 01-21-2024, 07:40 PM
Default Wiring
Thanks guys ,
