Old 05-21-2024, 12:12 PM
John Milner's Avatar
Default Crower Rod Bolt Torque Specs
Does anyone have the torque specs for the stock length/dimension Crower Sportsman Rods? They have the cap screw type bolts.
Old 05-21-2024, 03:31 PM
More importantly first is how many times would this be that they where torqued up?
If this this time would make 5 then they should get replaced if you do not want to take chances!
The sportsman with 3:8” bolts go to 47 to 50, and the 7/16” cap screw go to 70.
Old 05-22-2024, 09:10 AM
I believe this will be the second time that they have been torqued up. Thank you for that information.
Old 05-22-2024, 11:14 AM
Well if your reusing them that would be 3 times.
Old 05-22-2024, 07:33 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Sounds like the rod bolts are original. If so, they should be ARP bolts with the Crower number stamped into the head. IIRC mine are 90820. Go the Crower website and there is a link for Rod Torque Specifications which lists the bolt numbers used, recommended lubricant, and the required torque value.
Old 05-23-2024, 04:01 PM
Thanks for the replies everyone. Mine seem to have A1 006077 87 stamped on the head of the cap screw. That isn't cross referencing to anything that I can find.
Old 05-24-2024, 03:37 AM
Nobuddy Nobuddy is offline
My Crower Sportsman 6.8 Pontiac (SP93421B) rod tag says 75 ft. lbs., .005" - .007" stretch, bolt part number 90829 and lube 90894. Tag says made in 2014. Head of the capscrew is ground and laser etched, not stamped.
Old 05-25-2024, 09:55 AM
64-3Deuces's Avatar
I have stock length rods, SP93419B, with bolt 90820. These were made in November 2020 so probably newer than yours, hence the difference in bolt number. Also note the difference in markings on nobuddy’s rod bolts.
The torque specs are that same as posted by nobuddy, .005”-007” stretch, 75 ft. lbs. torque, and lube 90894 which is ARP Ultra Torque Lubricant.
Your stock rods should have the 7/16” bolts so you should be good with the specs listed.
Old 05-25-2024, 10:29 PM
I've never even heard of a Crower rod for a Pontiac that isn't 7/16" capscrew. Seems the only question should be if regular 8740 or a higher alloy.
Barry
Old 05-26-2024, 07:15 AM
The only way to for this to be done 100% correct regardless of what the torque number is to go by the stretch method.
