Old 01-12-2024, 10:23 PM
64Lemans 64Lemans is offline
Default 64 Lemans - Poverty Caps
Hello.
I recently purchased a set of original 14x5 rims and the PMD poverty caps.
Question. How do you install the poverty caps. I assume there are some clips needed. Do I need to drill any holes or do the clips go over the 5 studs somehow.
Any input would be greatly appreciated as you can see I have no idea !
Thank you !!!
Old 01-12-2024, 10:32 PM
Rich-Tripower's Avatar
You mean like these? No clips involved, they just press onto the wheel. The wheels have locating nubs around the perimeter of the center raised portion and the inner back side rim of the cap just fits over those for a friction fit.
ID:	626516   Click image for larger version
Old 01-12-2024, 10:41 PM
You have to carefully pop them on without denting them.
Getting them off you’re easily damaging them unless you take note of where the nubs on the wheel center are located.
Pry carefully with a tire spoon right where one of the nubs are located and you’re much less likely to bend up the bottom edge of the caps.
Prying between the nubs is how you ruin them.
Old 01-12-2024, 10:50 PM
65 Lamnas's Avatar
I'm probably not remembering correctly, but it seems there are 3 of those aforementioned "nubs" on the wheel. If the wheel surface is nicely painted, take care to protect it as the pry tools can mar the paint a bit.
Old 01-12-2024, 11:22 PM
It could depend on the year but some wheels have 3 nubs and some wheels have four.
My 14” wheels all have 3 and I had some 15” wheels with four.
Pictured below, a 14x6” early ‘70s disc brake wheel with 3 nubs and some custom-built 17x8s that were built off of 15” centers with four nubs.
ID:	626522   Click image for larger version
ID:	626523   Click image for larger version
Old 01-13-2024, 11:11 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Position the standard cap over two nubs first.
Then carefully push over the last third nub.
A very important hint.
Apply a small amount of vaseline on the outer lip of the 3 nubs which allows the caps to slide over much easier.
Below is a 1965 GTO wheel with red lines showing the 3 nubs.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 01-14-2024, 12:57 PM
69hardtop 69hardtop is offline
Getting on is easy…..getting off without scratching rims is a little more challenging. I taped up a medium sized pry bar but I think they make a tool for getting them off
Old 01-14-2024, 01:14 PM
Sounds like marking with a small paint dot where the nubs are may be a good thing before mounting so you know where the are after the caps are installed.
Old 01-14-2024, 05:09 PM
Default thank you
Thanks guys.
This is very very helpful.
Sorry for the delay in responding due to a good ole WI Jan snow storm.
Can't wait for summer to take out the Pontiacs !!
Old 01-20-2024, 02:35 PM
Chris65LeMans's Avatar
This. Don't even let a tire shop or garage take them off - pop 'em off yourself at home beforehard.
For removal, I use one of these https://www.amazon.com/JEGS-80857-Hu.../dp/B078WJB5K6 with a shop rag between the tool and the edge of the cap.
Old 01-20-2024, 03:40 PM
Sweet... Thank you !!
Old 01-22-2024, 09:00 AM
Andre's Avatar
Andre Andre is offline
If you study the wheels with 3 nubs, you will notice that one nub is 180 degrees across from the valve stem, so that would be helpful later.
Old 01-22-2024, 01:14 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Andre, you beat me to it. Going to the attic to ck my wheels in storage to confirm and ck for a date stamp. I like the Vaseline idea, what about a little anti-seize?
Old 01-22-2024, 07:42 PM
Thank you Andre as usual!!
Old 01-25-2024, 05:08 PM
DLNorth DLNorth is offline
Just a little side trip -
is there a demand for stock steel wheels?
(I have 5 that came with my Lemans, with no idea if they are original or not, but the rest of the car is.)
Dan
