Old 04-02-2024, 09:02 AM
461-69bird's Avatar
461-69bird 461-69bird is offline
Question Ign switch
Is there a way of bypassing the ignition switch? I'm having electrical problems when the key is turned on, nothing works and it won't crank. I have power coming into the car with key off but not when key is on. 69 Firebird
69 Firebird
472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120
Old 04-02-2024, 09:07 AM
Do your headlights work when there’s no key in the cylinder?
Old 04-02-2024, 09:18 AM
461-69bird's Avatar
No they don't
69 Firebird
Old 04-02-2024, 11:23 AM
When you open the door does the dome light come on?
Old 04-02-2024, 01:01 PM
461-69bird's Avatar
It's no longer there.
69 Firebird
Old 04-02-2024, 01:38 PM
Tandyman Tandyman is offline
I suggest you first disconnect, then clean and retighten all your grounds . When you know the
grounds are good then start troubleshooting from there.
Glenn
Old 04-02-2024, 07:28 PM
Scott Thelander's Avatar
May need adjusted?
Old 04-02-2024, 07:43 PM
johnta1 johnta1 is online now
May need adjusted?
He said headlights won't work? They don't need key on or off.
Grounds as said sound like a good start.
Old 04-03-2024, 02:55 AM
461-69bird's Avatar
Originally Posted by Scott Thelander View Post
May need adjusted?
How is this done Scott?
I'll check all grounds first
69 Firebird
Old 04-03-2024, 06:03 AM
You just had the motor out yet again for a rebuild and dyno session so any wires you disconnected to get that yanked out of there are what I would visit first.
Make sense?
Old 04-03-2024, 07:01 AM
461-69bird's Avatar
Yes Steve, going through everything I disconnected at the moment.
I've ordered another ignition switch just incase. It will take a while to get here though.
69 Firebird
Old 04-03-2024, 04:30 PM
461-69bird's Avatar
Sorted :-)
Cleaned all earths and had ignition switch off, so perhaps the rod adjustment helped?
69 Firebird
The Following User Says Thank You to 461-69bird For This Useful Post:
