Old 11-13-2022, 03:08 PM
Ramairnacho Ramairnacho is offline
Default 1970 dash board texture
I got pics back from just dash in LA California and they clain to have correct grain texture for a 70 71 dash board they call it fine comb texture I posted some pics . Does this look correct? Advise please. I realize it's more that AL knotch but I want correct texture. Dash restoration claims they can match exact texture too but haven't seen his work. Please shed light on this. Only other option I got is to go complete 72 up texture on entire dash and if I go that route will need a complete dash boards ash tray glove box and column. Thanks in advance and Facebook group says its a match
ID:	602107   Click image for larger version
ID:	602108   Click image for larger version
Old 11-13-2022, 05:43 PM
72projectbird's Avatar
I'd like to know also. I need to send my 70 dash out soon, and it be nice to replicate the 70 correct grain
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-14-2022, 03:05 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I used Just Dash for my 1970 Firebird with the Sandlewood interior. They correctly matched the dash to the darker tone used for that interior color and the texture looked perfect. That being said, it was 9 months for the work to be done.
The Following 2 Users Say Thank You to srmmmm For This Useful Post:
Old 11-14-2022, 04:00 PM
Worth the wait thanks for info .how about quality please share pics
Old 11-14-2022, 04:13 PM
srmmmm's Avatar
It will be about two weeks before I can get back to the restoration shop, but will get them for you then.
Name:	#39 Engine Bay 20220812.jpg
The Following User Says Thank You to srmmmm For This Useful Post:
Old 11-14-2022, 07:21 PM
Sounds great and I thank you
Old 11-23-2022, 09:03 PM
FunctionalShaker FunctionalShaker is offline
This is what 70 dash grain should look like.
Name:	70 Dash Grain.jpg
Old 11-24-2022, 12:22 AM
Thanks for pic
Old 12-28-2022, 03:42 PM
srmmmm's Avatar
Was finally able to get down to the restoration shop and take these photos of the dash cover texture on the one for my 1970 Firebird. Just Dashes in California was the supplier.
Name:	Dash Cover #1.jpg
ID:	604183   Click image for larger version
Name:	Dash Cover #2.jpg
Old 12-28-2022, 06:41 PM
I just saw an ad for NPD where they have the 70 dash with correct grain for sale now.
Old 12-28-2022, 07:04 PM
Trevor78 Trevor78 is offline
And did the grain change for the plastic and metal finishes or just the vinyl used for dash?
Old 12-28-2022, 08:55 PM
srmmmm's Avatar
When I blow up the actual photos, the grain pattern is the same on the dash, glovebox door and steering column valence panel.
Old 12-28-2022, 09:04 PM
I got an email from Mecum today that was publicizing the new dash exclusively from NPD in excellent quality.
Said correct for 70-77 cars ,,,, $1029
But idunno if that holds true for the earliest cars.
And 78-81 coming soon.
Old 12-28-2022, 10:54 PM
Makes sense, couldn't see them changing them. There was a reference to need these parts swapped if dash changed, they wouldn't have been a match anyway to that level.
Old 12-29-2022, 12:39 AM
Default The grain
Then yours is a correct restoration of the 70 dash? I learned 72 in up same. 70 71 same if I'm wrong please correct me I m not an expert.i have seen the 72 style texture on a 70 and it appears that texture has more depth than 70. When reinstalling ash tray glove box ect it does flash a bit . Hmmm you got Avery nice dash board!
Old 12-29-2022, 11:22 AM
TA455HO's Avatar
TA455HO TA455HO is offline
The thing I didn't like about the job that Just Dashes did for me on my 1971 dash was they left the leading edge of the dash WAY too thick if you look through the front window. They originally tapered to a fairly thin edge along the top leading edge. At Just Dashes they built up this area with new foam but didn't sand it down nearly enough (or at all) to make that a tapered edge. Result was that the leading edge is much, much too thick to resemble original. I sent the dash back to them at their expense for them to re-do it the right way. I think they just sent it back to me without doing anything but told me they had fixed it. I received it back exactly the same as it was when I sent it back to them to fix their work.
This problem they have is so common that 2ManyTA's would frequently point it out to people who have gotten their dash back from Just Dashes.
The Following User Says Thank You to TA455HO For This Useful Post:
Old 12-30-2022, 02:17 PM
Formulabruce's Avatar
'70 Sandalwood dash texture
Old 12-30-2022, 03:07 PM
srmmmm's Avatar
Here's a deeper view of mine. It was the single most expensive component of my restoration - $1850. They had to repair the lower metal bracket below the steering column, and the color match added to the base price as well.
Name:	Dash Cover #2 (2).jpg
