How is a WS6 T/A identified from a regular T/A?
------- Gary |
------- Gary |
The easiest way would be to find the window sticker, build sheet or PHS documentation. If you're trying to identify it on the car, you'll find either 15x8 aluminum snowflakes or Turbo style wheels(79 10th Anniv or 80-81). Also look for urethane front sway bar end links or the .750" rear sway bar. Measure the bar by taking a string and go around it(diameter), lay the string flat and measure it. Take that measurement divided by 3.14 and you'll either have something close to .625" or .750" Without factory documentation, it's kind of hard to tell otherwise. They'll have the 14:1 constant ratio steering as well.
[This message has been edited by Rocky Rotella (edited 11-26-2000).] |
Another clue is the round metal braces that connect the rear mount of the lower control arm bracket to the frame. These braces are approximately 4 inches long and are visible from underneath the car.
Aut viam inveniam aut faciam 1971 Trans Am 455HO M22; Cameo White / Blue 1971 GTO Convertible 455 M40; Starlight Black / Black |
the trim tag on the firewall will have the ws6 option code on it also. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
Mike, is that for sure? I know the body tags all had "WS4" on the T/A's but I was never aware of "WS6"
i've had a customers car in that was marked ws6 on the cowl , it was a 78 trans am. i also have a freind that has owned an 81 bandit edition ws6 t/a and a formula that was ws6. unfortunately the formula was totaled. it was a factory 4spd car,342 posi with a 301. all of these cars were marked ws6 on the cowl tag. mike
