PLX DM6 AFR gauge anyone?
Thinking about getting one. Very simply hook up and easy to use IMO.
Shows real time readings and stores the max & lowest readings. All I want...Jeg's has them for $251.99.... http://www.jegs.com/i/PLX-Devices/687/SMAFRDM6/10002/-1 My Innovate LM2 is just too damn complicated for me..I'm just a old Redneck.. Would like to hear from any users... Thanks Troy
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. Last edited by 60man; 01-19-2014 at 10:56 PM. |
OK......What AFR gauges are you using.??
Something simple and not complicated....such as Innovate is. Probably be selling my LM2 and related stuff... I do want something that will hold readings I can retrieve after run.... Looks like link has stopped working....sorry
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. Last edited by 60man; 01-21-2014 at 09:39 AM. |
Troy I have the LM-1 with the rpm convertor and I like it. The thing with only using a AFR guage is you have no idea what rpm anything was arrived at looking at the graph. Their really only good for WOT then, and even then u should pull a plug
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
I hear ya Darby.. I haven't had much success with the LM2...
Sent it back to Innovate twice and they said it was fine.....guess it's my DA brain.. I'm not trying to coach every horse out of motor....just don't want to roast it!! I still read plugs..... I think (IIR) this gauge has a warning alert too...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Another thing, you wouldn't know if the high temp was actual or a spike.
I still use my LM1. |
Guess I need to become a high tech Redneck...
never used one on the nitrous motor.
I bought a cheep(500) o2 logger. Money WELL spent. logs rpm/o2 for entire run
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
What is it Mike??
