Old 02-11-2024, 01:37 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Default Camshaft Question Interchangeable
Hi
Dumb question but is a hydraulic FT Pontiac camshaft say for a 350/400/428/455 interchangeable with a Chevrolet camshaft say for a small block 350/383/400, or say a big block chevy 396/454?
I assume no all accounts, probably the snout of cam is what is different and or distributor gear location on stick.
curious if big block and small block chevy hydraulic flat's can be swapped between them?
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 02-11-2024, 02:00 PM
No, don’t even waste time thinking along those lines.
Old 02-11-2024, 02:16 PM
kyle_blake's Avatar
Ok thanks. Learned something new. Appreciate it.
Old 02-11-2024, 02:27 PM
Couldn’t be more different.
Absolutely no.
Pretty much nothing is interchangeable between Buick, Chevy, Olds. Cadillac and Pontiac V8s other than the distributor caps and carburetors.
Each brand designed their own completely different engines.
