Old 04-14-2021, 06:26 AM
fbd73's Avatar
fbd73 fbd73 is offline
Default Headlights not working
Hi all,
For some strange reason the headlights on my '73 Formula have stopped working. Parkers and taillights work fine.
I went to check the fuse but couldn't find one that says 'headlight'.
Has anyone got any idea of what I can check?
Old 04-14-2021, 06:48 AM
johnta1 johnta1 is online now
Try pushing the dimmer switch. (with headlight switch on)
The power goes from the headlight switch to the dimmer switch then to the headlights.
Check for voltage at the headlight switch (lt. blue wire I think), then dimmer switch.
More than likely the dimmer switch is bad?
If not the light switch?
Old 04-14-2021, 07:43 AM
Some pics:
ID:	564676   Click image for larger version
Old 04-14-2021, 03:15 PM
Formulabruce's Avatar
Newer replacement Dimmer switches can get caught on the carpet grommet, as they are too tall and the top part can stay above that Gromnet. I rebuild old ones for this reason.
Old 04-14-2021, 05:01 PM
fbd73's Avatar
Thanks heaps guys. I would never of thought of the dimmer switch. I will check it this afternoon when I get home.
Old 04-15-2021, 04:53 PM
fbd73's Avatar
You guys are amazing.
I turned the headlights on and then got down and removed the edge of the carpet and floor mat and just wiggled the dipper switch and then checked the headlights and they were on.
I'm not sure though if I need to do anything else i.e. check for loose wiring or if the carpet/floormat was the problem.
I will keep a check on it.
