Old 02-05-2024, 05:44 PM
JBanna's Avatar
JBanna JBanna is offline
Default Battery Cable Questions
Hello again all,
I'm going to replace my stock battery cables with lower guage versions to hopefully help with a slow when hot starter problem (I have already replaced the starter, which did not improve the problem). I was worried about the heat issue when I switched to headers over 40 years ago, but didn't really have any problems until the last year or so; of course, the original 403 was a bit smaller than the 455 (Pontiac version) I swapped in 20 years ago, but the starter seemed to handle it ok, even with a compression ratio of 10:1. Anyway, where can I source these new cables, and what are the stock lengths for a 78 Trans Am? They are probably the same for either the 403, 400, and 455, but I'm not sure, and my searches are not giving me concrete answers.
Thanks,
Joe
78 White T/A, Carmine interior, Fisher T-tops, WS-6 package, 3.08 gears, a/c, rear discs. Original 403 with 300,000 miles replaced by new Pontiac 455 (roller everything, 6x-4 heads, Performer manifold, Hooker Headers, Hughes converter, Cliff's Q-jet) - I only get 12 mpg!
Old 02-05-2024, 06:12 PM
bdk1976 bdk1976 is offline
I used 1/0 welding cable from ebay - works great.
Old 02-05-2024, 08:52 PM
vertigto's Avatar
vertigto vertigto is offline
BatteryCablesUSA...great prices and quality.
https://www.batterycablesusa.com/battery-cables
Old 02-05-2024, 09:22 PM
Made up my own with some marine battery terminals and large lugs using 2/0 welding cable. I mounted a Ford solenoid to act as a relay and used a copper buss to jump between the positive post and the starter solenoid. This way the positive cable on the starter isn’t hot until the Ford solenoid is activated.
I used the stock positive connection that’s located on the inner fender at the horn relay to mount the Ford solenoid and link that post to the Ford solenoid using a heavy copper buss. This installation is on my ‘64 Le Mans convertible.
The last picture is my ‘64 Tempest when it had a Tri-Power 455. It had a similar Ford solenoid installation and the same 2/0 battery cables I made up, the solenoid is visible near the fender edge. Never any problems starting with a flick of the key in any weather.
ID:	628011   Click image for larger version
ID:	628012   Click image for larger version
ID:	628013   Click image for larger version
ID:	628014   Click image for larger version
Old 02-06-2024, 01:50 AM
Geoff Geoff is offline
I would buy a modern mini/reduction starter...& use with your existing cables.
You could buy thicker cable for the existing starter & still have the problem. Then what?
Old 02-06-2024, 08:11 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I got mine from American Auto wire, cut to fit. Nice but not cheap. X2 on the mini starter, I've had great luck with Powermaster
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.72@112, 1.58/60
The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60'
Old 02-06-2024, 09:43 AM
Lee's Avatar
Lee Lee is offline
I've been using these guys for years. Great product, great service.
https://custombatterycables.com/
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 02-15-2024, 04:00 PM
JBanna's Avatar
Thanks everyone, I'll find some for sure; upgrading the cables is simple enough, so I'm going to give it a go - the existing cables are 20-30 years old, so it's probably about time anyway! If I still have problems, I'll look into a reduction starter...
Old 02-15-2024, 04:02 PM
Stuart's Avatar
Stuart Stuart is offline
They make a heat shield that covers the starter, one of those may help as well.
