I broke the original rear end in my 66 GTO back in high school (1987). I kept the bare housing to one day reinstall. For the last 20 years, I've been running a 3.23 open rear I pulled from a 66 Cutlass. It's the same housing as my original (BOP 8.2 10 bolt). I just had all new parts put in my original housing (3.55 gears, Yukon posi carrier). I put the axle in the car, and went to install the axle shafts from the old rear into the original one, and they are about 3/8 to 1/2 inch too long. They bottom out before the bearing seats in the housing. I know they made wider axles in later years (67 and up I think), but both of these housings measure the same flange to flange.
Do I need to get new axle shafts that are shorter? Can the originals be shortened? Any help is appreciated. Thanks, Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
just to clarify
these are the same axles that was in this housing?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Yes, many years ago.
If "the old rear" is the "original one" i canīt see the issue unless the Yukon posi is wrong in some way or the splines on axle shafts are twisted.
That's what I can't figure out either. The axle shafts are the same ones that came out of this rear end 36 years ago. They've been in a 66 Cutlass rear for the past 20 years. The splines aren't twisted, they're bottoming out. Doesn't make sense. I've reached out to Yukon to see if they can help.
it sounds like the carrier is at fault
Kenth good call on splines being twisted
A while back when i was sorting out the current car i have, a friend noticed a wheel on one side would wobble driving. Turns out the car was hit on that side and the axle flange was bent. Bought a new one from Yukon; had the bearing pressed on and it bottomed the same way you state. The axle also came with a collar 9spacer) that gets pressed on similar to the bearing. Turns out the collar gets pressed on first, then the bearing, moving the bearing towards the carrier. Didi that and fits fine.
The whole point is: did Yukon change the diff to accept their axles? George
![]() Quote:
I heard back from the supplier, and they said it's not uncommon for axles to need to be trimmed about 1/8 inch to fit their carriers (no idea why, and I didnt ask). Mine needs more than that, but they told me as long as I have a minimum of 7/8 inch spline engagement, I'm good to cut the axles down, so that is what I will do. I'm going to measure more precisely and then cut them. Thanks everyone for the input! Importsmasher
True on the brake shoes and drum comment, so never mind.
George
so it sounds like the issue is indeed the carrier.
Like the splines arent machined as deep as OEM
Yeah, that is apparently the difference. I'm not going to pull it back apart to compare though lol.
Ask Yukon
I did. They're the ones who told me I might have to cut them down 1/8 inch. BUT.......
I went out to the shop today, to measure exactly how much I needed to cut off, and I noticed there wasn't much room between the wheel seal and the bearing retainer on the axle shaft. I tested that theory, and it turns out the bearing retainer was hitting the seal. That was the solid "bottoming out" i was having. I pulled the seal out and the axle went right in. Upon closer inspection, they builder had installed the seals backwards! Problem solved. My first thought was, what else might he have screwed up? But he comes highly recommended by several people, and as the seals are kind of unusually shaped, I can see how it happened. I didn't realize they were in wrong until I removed them. Thanks for all the input!
The Following User Says Thank You to importsmasher For This Useful Post: | ||
