Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Closed Thread
Old 04-18-2019, 01:16 PM
Robsinno1's Avatar
Robsinno1 Robsinno1 is offline
Default 900HP Pontiac 535 all Aluminum engine for sale - $15,000
Engine built by Kauffman Racing has 50 passes since freshened and 68 passes since new. Over $25K invested. Selling for $15K.
Kauffman MR1 Aluminum Block
Bore - 4.350” Stroke - 4.50”
Crankshaft – Ohio Forged Steel
Journal size - 3” main
Connecting Rods - GRP 6.8” Aluminum
Pistons - Ross with Total Seal Gapless 2nd ring
Camshaft - Comp Standard Journal
Cam Specs - (51000-13) 790 int. – 773 Ex. – 112LB Duration 277* - 282* grind # P812305B/2237B R112
Heads - high port Kauffman with offset valve train. Flow numbers - 400cfm. Chamber CC - 64cc
Compression ratio - 14.7:1
Victor Pontiac Intake manifold w/plenum work and ports matched. Intake Spacers welded.
Valves - Int. .220 Ex. .170 Springs - Comp Pacaloy
Lifters - Isky Red.
Pushrods – Hardened 3/8”
Rockers - T&D shaft 1.7
Custom made Tall Aluminum Valve covers with recessed Allen head bolts
Water pump – Menzier Electric Aluminum (Red)
Distributor – MSD Pro Billet
Vacuum pump – Moroso 3 vane
Harmonic balancer – Rollmac
Oil pan – Custom Langer split rail – 7qt
Oil pump – Melling 60lb
Crank scraper – built into oil pan
Valley pan – Aluminum
Email: rasoule@charter.net
ID:	510467   Click image for larger version
ID:	510468   Click image for larger version
Old 04-18-2019, 03:06 PM
slowbird's Avatar
slowbird slowbird is offline
What did it run in the car and weight of car?
Old 04-18-2019, 03:37 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
this is the car it was in. i believe it was right at 2500 with driver. we bought the car and with an iron ia2 and gutsram it weighs 2600 with driver
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 04-18-2019, 03:47 PM
Pearlbluebird's Avatar
Pearlbluebird Pearlbluebird is offline
I was running 8.20's in Norwalk in 2017 with that motor.
A second class drive is better than a first class walk.
Old 04-18-2019, 05:13 PM
Robsinno1's Avatar
It ran 8.26 at 162 mph in a 74 TA that weighed 2320 lbs. Bought the motor from Pearl Blue Bird, but never used it. Too many modifications required to make it work in my car.
Old 04-18-2019, 05:14 PM
Robsinno1's Avatar
Sorry, it was not in that car....not the same car or motor
Old 04-19-2019, 11:45 AM
Mark G Mark G is offline
Yes same car same motor Good Luck with the sale .. Free Bump...
Old 04-19-2019, 12:11 PM
Robsinno1's Avatar
Sorry but you are wrong, this is not an iron IAII block, it is a Kauffman MR1 Aluminum block as stated. Here are pictures of the car it was in with the motor in it and next to it.
ID:	510540   Click image for larger version
ID:	510541   Click image for larger version
Old 04-19-2019, 03:10 PM
Jim Zeek's Avatar
http://forums.maxperformanceinc.com/...d.php?t=811370
this is the link i put in my response. i don't know why it didn't show up. i bought deryks car. i put an iron ia2 in it. sorry
Old 04-19-2019, 09:59 PM
10second70GP's Avatar
10second70GP 10second70GP is offline
Nice build and a great price GLWS .
Old 04-19-2019, 10:40 PM
I never said it was a iron block you got from a good friend of mine .. Good Luck
Old 04-20-2019, 07:17 AM
Robsinno1's Avatar
Sorry that was meant for Zeek, and thanks.
Old 04-20-2019, 11:36 PM
aaronman aaronman is offline
PM Sent.
Old 04-22-2019, 01:46 PM
Spent some time talking with Bob about this engine. This is a really good price for a proven combination.
Old 05-16-2019, 09:45 AM
Robsinno1's Avatar
bump
Old 05-16-2019, 02:36 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Are you looking for a less radical engine? If so, I have the engine below if you are interested in some type of trade? Dyno time only on it.
http://forums.maxperformanceinc.com/...d.php?t=776790
www.lancablingsolutions.com
Old 08-29-2019, 11:40 AM
Robsinno1's Avatar
BUMP
Old 10-04-2019, 12:50 AM
Robsinno1's Avatar
Lifters - Isky Red.
ID:	521439   Click image for larger version
ID:	521440   Click image for larger version
ID:	521441   Click image for larger version
Old 10-15-2019, 01:40 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
This is a steal, most likely way more than $25k invested too
Dave Polichena
Old 11-01-2019, 12:38 PM
Robsinno1's Avatar
Lifters - Isky Red.
ID:	523387   Click image for larger version
ID:	523388   Click image for larger version
ID:	523392   Click image for larger version
ID:	523393   Click image for larger version
Closed Thread
