My new project 1980 Turbo T/A
Hi all... new to this forum. I recently bought a 80 Turbo Trans AM WS6 and was looking for your thoughts on direction. The car is original Silver with a red cloth interior. It's in very original condition, but the motor is shot and IMO not worth reviving just to state it's numbers matching.
Here's my thoughts... 1) Only needs one spot of body work on the Driver's side quarter. I'm going to pay to have that fixed and repainted. 2) Pull the engine and trans and put them on a stand so it retains its numbers matching drive train. Install a crate 350 with a rebuilt transmission. The car should run fine and the crate engines can be had in 350HP long blocks for $3200. 3) Either leave it like it is and get it running, or put some 17 inch honeycombs on it and paint it either green or 80 Maroon. Thoughts? |
My thoughts are cover that crappy Edelbrock air cleaner to keep the rain out.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
nice looking bird. personally i would keep/rebuild the original turbo engine... especially over a 350 chevy!! why is the motor "shot?" the 301t isnt the most loved engine but can be made to run pretty decent with not much work. $3200 will build a 400 pontiac to have just as much power as the crate chevy & will be a much easier install.
as for paint, do it the color you like but IMO, silver on red is one of the best looking color combos for these cars... & green will NOT look good with red interior. dont get too crazy on the color combo, green on red will not have much resale value come time to sell it. & roller tip rockers fit under stock valve covers with a single stock gasket. & in the future please resize your pics to smaller so they can be viewed better, those are way too big for forum use. |
I'll disagree on the 301 too. It's a dog engine and everyone knows that. It was the end of an era and the turbo 301 is not a good engine. Replacing it with a 350HP 350 Chevy (also GM BTW) with a warranty is a reasonable compromise IMHO. I know the haters will hate, but let's get real here. What is the most bang for buck? What I'll most probably do is install the crate engine and leave it as is. If the next owner wants to revive a putrid 301 that's number's matching then they have the choice. They won't... why would you if the car runs well? |
would have to disagree with you on the cost to build a mild street pontiac & most others on here who have done it probably would too.
yes parts are cheaper but machine work is machine work & costs the same for most motors. i didnt mean aluminum heads & stroker kits or custom pistons etc, just a good mild street engine with common parts. you can build a 350 hp pontiac 400 with stock crank & even rods at that power level but the RPM forged rods arent much more than rebuilding stock rods... a good cam selected with a very easy to reach 9-9.5:1 comp & you're easily at that HP with more TQ than a SBC. & the stock mounts, fuel lines & wires hook right up. im aware there are a lot of haters on the 301 & 301t, but have you ever owned one that ran right? they were within 10 HP of a 78-79 W72 400 rated at 220hp, the 400 had more tq & that meant faster off the line or seat of pants feel, but at a 30-40+mph roll they will hang right with the 400s. i own an 81 301t & its 99% stock, runs 14.8 in the 1/4 not full throttle on hard old street tires, not "fast" by any means but almost a second faster than a stock W72 400 times. & there are lots of guys running them into the 13's & a few in the mid 12's using stock heads, turbo, carb etc in a NHRA class. so they arent as bad as the rep they got over the years. keeping the 301 was just a suggestion mainly for resale value depending on what you plan to do with the car. if youre keeping it for awhile, do what you want to it, if it will get sold, staying pontiac will most likely pull more money. bang for the buck? pontiac all the way! just my thoughts. |
https://www.jegs.com/i/ATK-Engines/0...791+4294829509 If you want to back up your stand that you "can" rebuild a Pontiac for less than a Chevy, please provide an example compared to the one posted. The 301 is a dog engine. If you want to tweak it to eek out a little more horsepower, you will still wind up with way less than 350HP, and it will cost you a ton to do that; not to mention the difficulty in dealing with the turbo... which is prolly bad and needs a rebuild. The 1980 Camaro had a Chevy engine. This isn't a GTO that never had a Chevy engine. That means the parts you buy for it are plug and play. In this day an age one must factor in all the variables in order to make a sound decision. IMHO, the Chevy 350 in this car is the only real viable option. If you disagree, please explain the error of my plan. Last edited by thews; 05-30-2020 at 07:11 PM. |
Don't forget to change all of your accessory brackets and trans....but sounds like you got it all figured out.
_____________________________ She woke up sunny side down and I was still thinking I was too proud to flip her over |
not trying to argue about it, i didnt say for less, i said you could build a 350hp 400 long block for $3200.
it is a fact that you can build a 350hp pontiac 400/455 with common parts that arent that expensive, i've done it & there are plenty of examples on here to back it up. its obvious you dont like the 301t & thats fine... i never implied it was a high hp race motor. but when running right they are not too bad for what they had to work with. also never said make the 301 350hp or compared it to the crate sbc, was just a "thought" on keeping it depending on what the plans were for the car... & by things hooking up easy i meant you dont need to change or reroute factory fuel lines, change motor mount locations or modify wire harness etc. sorry for mentioning a few things when you asked for thoughts... sounds like you got it all figured out with the chevy. |
This is why I bought my 81 turbo, all original. Mostly everyone that buys these cars chucks the engine , which will be good for the guys that keep them they way Pontiac made them . It will never be a fast muscle car but a great car that the Pontiac guys tried to make a great effort and engineering to keep the Pontatic V 8 Alive . I have had over the last 40 years cars that had 500 to 600 hp for me those days are over . But I am sure if you keep it silver with the red interior it will a great looking car , good luck
The Following User Says Thank You to grd777 For This Useful Post: | ||
Ok, maybe you can rebuild a P400 for $3200.00, but unless he has a P400 laying around he has to buy that too.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
can buy a P400 block/crank/heads for $250-500... doesnt change the fact you can build a 350hp 400 for 3200 or less.
My 81 T the guy had started taking the 301 motor apart and was going to do a 455 swap but not all the parts for that. Put a stock style 400 together in it for my kids to drive to high school with 6X-4s I found at a wrecking yards I pocket ported and threw a vale job on.. Getting the interior back in shape on it cost more than the motor to build. Heck last weekend put fresh gas in it and fired it up again.
The 301T has head studs and supposedly an Ultradyne cam in it Was running a Holley 3310 on it when it was running but I never saw it run.
Just want to clarify that I have two extra Pontiac engines (both 400's) a 73 block/crank only and a full short block out of a 75 big car. I also have the RAIII intake and multiple sets of rebuilt 400 RAIII heads (#48, #62). If I start with what I have, it's still going to cost more than buying a 350 Long block rebuilt at 350HP. I'm not knocking a Pontiac engine... I love them. I have 2 69 350HO convertibles and one has an original 4-speed engine (not running) and the other (running) has a 68 Catalina 400 rebuilt and it runs awesome. The bottom line is that, IMO, this particular car would be better off with the Chevy 350 for $3200 shipped. It would have a Chevy $1200 rebuilt transmission and engine with a warranty when I go to sell it. I get Pontiac love... I bleed Pontiac blue, but in this case, logic has to set it up so I don't lose money on it. It's a cool car because it handles and 1980 sucks for performance. I'll correct one wrong and right the other.
I vote keep the silver color!!!
I'm in. All I'll do is make it run well and leave the rest of it as is. I'ts very unique.
Putting a crate motor with a warranty is almost a no brainer imo.
For all the naysayers, I had my 400 built, lots of extra HP, for $3200. I just got a quote from the same guy to do the 400 for my 79, same price. |
oil pan timing cover harmonic balancer valley pan windage tray pulleys motor mounts When you add it all up, if you have 3 timing covers and make one work, you do that, but when you pay for all this stuff, it's not cheap. I love my Pontiac engines, but when I know I also want a rebuilt 400 transmission and it's only $1200 for a Chevy with a warranty, ok... I get to drive the car. When the hood isn't up, it's still a hot rod. When the hood is up, at least it's not a 301. Thanks for the input... I won't change the outside other than get the dent painted, and I'll clean the interior and add a stereo. Should be a cool car when I'm done. What I didn't realize until now, is that this Trans Am is about the lowest flash T/A I can imagine. It only says T/A on the deck lid and on the fenders, no bird and a neutral color. Whoever ordered it didn't want to be noticed. Last edited by thews; 06-01-2020 at 07:38 PM. |
I'd keep it Pontiac V8, the supposedly cheaper cost of 350 horse chevy 350 build doesn't hold water. When you're done, what do you have? Another no one wants it bread & butter Chevy 350 in a 2nd Gen Bird, in other words, you just shot off a couple toes.
In a traditional Pontiac V8 swap, the 301 Turbo engine's PS pump can be used in a swap, so can the 301 Turbo's crank pulleys, you'll need two common (& cheap) small stamped steel '71+ PS brackets, either a '71-74 Pntiac v8 front alt mtg plate (or a '75-79 version), & a 481040 wp pulley. $50-60 outlay plus ship by most longtime used parts vendors.
IMO, by 1980 the hood bird had about run its coarse. Wild graphics were a product of the '70's. I remember when I got my '82 firebird I got a lot of comments like 'does it have the silly bird on the hood?' In retrospect nothing says trans am to me now like that massive decal of a fire breathing pheonix!
Thread Tools | |
Display Modes | |
