Old 04-25-2021, 04:05 PM
bluejudge bluejudge is online now
Default Master Cylinder
I am looking for an original Master Cylinder for my Arlington built 70 Judge. Build date is 9C. What is the correct part number and date code. Thanks in advance. Marc
Old 07-05-2021, 08:34 PM
rare4k's Avatar
rare4k rare4k is offline
Should be 5470409 with a bore size of 1 1/8 and a stamping of EB in the front with side bleeders
Sent from my moto z3 using Tapatalk
Old 07-06-2021, 05:37 AM
Thanks, anything on the date code range? Thanks, Marc.
Old 08-11-2021, 01:20 PM
Tim Corcoran's Avatar
Rebuild it
Tim Corcoran
Old 11-02-2021, 07:57 PM
Originally Posted by Tim Corcoran View Post
Rebuild it
I don’t have the original one in the car.
Old 11-21-2021, 09:57 PM
Dont _____ me Dont _____ me is offline
Default Is this it?
Is this it? The part # is 5470409. But I can't find a stamp number. Also a 70 Oshawa Judge. Cdn. Does this stuff look original? Thanks!
ID:	578332   Click image for larger version
Old 11-24-2021, 12:55 PM
rare4k's Avatar
No bleeders, so I would say remain
Old 02-28-2022, 09:14 PM
rare4k's Avatar
Is this car a Late build ?
Old 03-01-2022, 01:24 PM
[QUOTE=rare4k;6322722]Is this car a Late build ?
My car was built 9C, third week of September. Thanks, Marc.
Old 03-01-2022, 06:47 PM
RamAirBirds RamAirBirds is offline
Being an early built car it would quite likely be a small font "EB". The one shown in the photo is a Large Font version. Not sure when the change over happened.
My 10C built car has the small font....much smaller...
RA
Old 03-01-2022, 07:24 PM
Scott Thelander's Avatar
never seen the numbers nest to the B before on my originals
it a clean stamp on that master ,, and yes the font looks tall ''
Old 03-02-2022, 07:01 PM
Don't forget that the metering valve was also dated starting in 70 models...Stamped right next to the brake line out on the flat surface of the pad. fairly visible when everything together on car.....
Old 09-25-2023, 10:07 PM
After looking at a few build sheets I see a DH in box 68 for the master cylinder. These are early builds for the 70 GTO. I do not see EB. Am I reading it wrong or does the DH on the build sheet mean EB on the master cylinder. I am confused. Thanks, Marc.
Old 09-26-2023, 05:52 AM
Judge273's Avatar
Judge273 Judge273 is offline
The stamp on pad is different of the tag on retainer.
UD on tag and DP on pad. 71 power drums…
Sent from my iPad using Tapatalk
Mike/Illinois
Old 09-26-2023, 09:29 AM
I attached a build sheet this is for a 70 GTO built is Arlington if you look at box 68 it says DH. If you are saying that is the tag letter for the master cylinder and it is stamped EB then I understand. Thanks, Marc.
