Old 10-20-2023, 04:40 PM
tom s tom s is offline
Default 76 Shaker assm info needed
A friend bought the Shaker scoop from Classic and needs what ever necessary to install it?Have not found a kit to mount it to the carb.Tom
Old 10-20-2023, 06:03 PM
Trevor78 Trevor78 is offline
An aircleaner base?
Old 10-20-2023, 06:33 PM
We need every thing but the Shaker scoop.Tom
Old 10-20-2023, 09:04 PM
nas t eh nas t eh is online now
Buy a used air cleaner base for a 1973-76 Trans Am all the other items needed are available from Ames in reproduction. But sold separately not as a complete kit. You will need the scoop to hood gasket, the drain hose, the scoop to aircleaner base retaining ring, the air cleaner lid/cover and the crank case vent items to keep the scoop from rotating on the base.
Maybe when you buy the used base you will also get some of the other pieces like the air cleaner lid/cover and retaining ring or some of the vent items like the filter and retaining clip.
73 T/A 455, 4speed
Old 10-20-2023, 09:27 PM
Thanks!
Old 10-20-2023, 10:27 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
It’s worth noting that the 73-74 air cleaner base is very similar to the 75-up base, but the Quadrajet vent tube is slightly repositioned on the later units, so the air cleaners clock differently on the opposite carburetor.
The Following User Says Thank You to Rocky Rotella For This Useful Post:
Old 10-21-2023, 05:11 AM
Tom, do you have the 76 Assembly Manual? Might be handy for seeing how the components all go together and what each does.
Old 10-21-2023, 07:04 AM
The car is 2 hours from me at a shop.No manual,will get see if Franks has what they need.Tom
Old 10-21-2023, 10:09 AM
Held for Ransom's Avatar
I'll post pictures to help.
A hood scoop with nipple affixed (missing in picture).
A drain tube (missing).
A scoop seal.
An air cleaner retaining ring with screw and nut.
A carburetor stud (missing).
A wing nut (missing).
An air cleaner lid.
An air cleaner base.
Attached to air cleaner base...
-two vacuum hose thermal sensor.
-vacuum break valve with clip.
-single vacuum hose choke sensor.
- air heat duct elbow with clamp.
An air filter.
An air cleaner breather filter with clip.
A valve cover to air cleaner vent pipe with hose.
And not shown are the fresh air ducting pieces.
ID:	622006   Click image for larger version
ID:	622007   Click image for larger version
ID:	622008   Click image for larger version
ID:	622009   Click image for larger version
So long, farewell.
Old 10-21-2023, 11:15 AM
Thanks,seems like the most important right now is for us to find a AC base,the lid is avail.Tom
Old 10-21-2023, 12:54 PM
Depending on what kind of hurry he's looking at, there are a couple on eBay, if you or he does it.
Not so good deal...
https://www.ebay.com/itm/225703584642 or
https://www.ebay.com/itm/155589641545
An OK deal...
https://www.ebay.com/itm/225772508586
Here's a late '75 unit...
https://www.ebay.com/itm/335066279880
So long, farewell.
Old 10-21-2023, 01:28 PM
Tom, should be able to beat any of the eBay prices on a combination of correct pieces.
Have put together several correct shaker base/lid/ring/PCV tube packages for PY'ers & other T/A owners.
Will be in later today & can send you pics.
Old 10-21-2023, 02:30 PM
Thank,like said,have the original 76 carb on the engine and we bought the new shaker from Classic.Just need to mate them up.Tom
Old 10-22-2023, 06:39 PM
Tom, check your PM.
Old 11-04-2023, 10:33 PM
We got the base from a PY member!Going to order the other parts from Ames.Tom
Old 12-19-2023, 10:36 PM
Got what we needed!Tom
