Old 12-16-2022, 04:55 PM
1971formula400dave 1971formula400dave is offline
Default Edelbrock head porting
So I want to get my heads ported into the 300 cfm+ range. Anybody have some recommendations. I was going to have butler but there 4 months out. Looking for quality and if I have I’ll wait
Old 12-16-2022, 07:38 PM
64speed's Avatar
64speed 64speed is online now
My heads were ported to 325 by Butler. Worth the wait
The Following User Says Thank You to 64speed For This Useful Post:
Old 12-16-2022, 07:55 PM
Contact Paul Knippen who posts here regarding his work load. He was involved with some of Jim Butlers Edelbrock CNC programs. Cell 630-400-441
Old information here:
Old 12-16-2022, 08:06 PM
25stevem's Avatar
25stevem 25stevem is offline
You’ll also need to have the intake manifold flange port exit raised up 1/8” to RA4 gasket size and if you want to use all of that 300 cfm to make hp then that new RA4 gasket height needs to go all the way up the runner to where it meets the plenum.
If fact on the way up the runner that port area needs to expand, not just stay at RA4 size.
I do stuff for reasons.
Old 12-16-2022, 08:47 PM
"Cleaning" up a set of Edelbrock cylinder heads to approach or at your proposed 300 cfm, this at 28" and 0.600" valve lift.
From the internet...
The intake bowl is opened up and blended to the rectangular intake port. Very little material is removed.The intake runners are widened at the pushrod bulge and the floor of the runner is widened to the valve bowl transition with a generally trapezoidal shape.
After the porting, a multi-angle valve job is performed and the heads are cc'd. The intake runners are also cc'd to verify the proper amount of material removed.
The exhaust ports are very good out of the box and need only a little massaging on the short side of the port.
Not rocket science for a good head porter
Old 12-16-2022, 09:55 PM
slowbird's Avatar
slowbird slowbird is offline
Paul does great work
The Following User Says Thank You to slowbird For This Useful Post:
Old 12-16-2022, 10:34 PM
mach flyer mach flyer is offline
Hey Steve,
You’re missing a digit in Paul’s contact number …
Old 12-16-2022, 11:08 PM
slowbird's Avatar
Originally Posted by mach flyer View Post
Hey Steve,
4441
Old 12-17-2022, 10:52 AM
78w72 78w72 is offline
SD performance. not sure on the time frames but one of the best & original CNC porter for pontiac heads. https://www.sdperformance.com/
most intakes dont require the flange to be raised to use RA4 gaskets, at least not factory intakes, ive had SD do their full intake plenum & runner porting, the RA4 gasket fits & seals fine on iron & HO aluminum intakes.
Old 12-17-2022, 11:01 AM
Sorry for the confusion on Paul's number. Slowbird is correct.
630-400-4441
Old 12-18-2022, 01:54 AM
I was reading your motor info, she sounds like a fun car to drive. Did you ever dyno it? Just curious
Old 12-18-2022, 01:55 AM
630-400-4441
Thanks, I’ll try him on Monday
