Old 11-10-2019, 07:51 PM
Wick's Avatar
Wick Wick is offline
Default 1976 Trans Am 455 4 Speed Drivetrain
Just picked up a complete '76 drivetrain from a TA. Subframe, motor, trans and rear. The guy just dropped it all out to build a PT car so all brackets, shifter with linkage and all. I'm having trouble finding the codes for the rear, this appears to have a PT G82341 stamped on the rear. The trans looks like a ST10 but has a cast iron case? I thought ST10 were aluminum. Any thoughts or help?
_____________________________
She woke up sunny side down and I was still thinking I was too proud to flip her over
Old 11-10-2019, 08:52 PM
tom s tom s is offline
There were castiron ST-10s.I have owned a coupe.Note,early T-10s also came with a iron case.Tom
Old 11-10-2019, 09:24 PM
Try this for the axle:
Axle Code Search
Put PT in the input box.
Old 11-15-2019, 01:22 PM
John Milner's Avatar
John Milner John Milner is online now
Look and see what the number is on the passenger's side of the transmission case. I think some 81 Camaros came with a cast iron case super t10 and there was an over the counter super t10 with a cast iron case and tougher gears. The cast iron case should be a 904 case.
Old 11-24-2019, 09:19 PM
Wick's Avatar
Correct, the 904 case was later I have read. Looks like the aluminum cases were giving a little trouble so they went iron beginning in late '79 or early '80. There are no visible numbers on the VIN pad on the passenger side. Still doing a little research.
Anyone have the correct carb number? I can find the '76 400 carb numbers.
Old 11-24-2019, 09:36 PM
blue71ta's Avatar
blue71ta blue71ta is offline
17056263, same as the 400-4 spd
Old 11-24-2019, 11:09 PM
Wick's Avatar
Same as the 400? Thanks, didn't know that.
