Old 01-14-2021, 11:09 PM
brodad brodad is offline
Default Power steering/alternator bracket help
I'm in need of some help with the brackets, I have the pieces but need help with the placement/order of them on my engine. 67 400 block, 11 bolt timing cover with short water pump. Any images/good exploded views would be greatly appreciated. TIA
Old 01-15-2021, 01:10 AM
ignaro's Avatar
ignaro ignaro is offline
I just bought new brackets for my motor. It came with this illegible diagram. Googling around, I found a better version. The 2nd alternator bracket is supposed to go on the thermostat housing but it fit poorly for me and I think one is enough. Not sure if I have everything right. My power steering pump is different so I had to grind the cast aluminum bracket a little for clearance.
Sent from my SM-G988U1 using Tapatalk
