Old 04-28-2024, 05:57 PM
grivera's Avatar
grivera grivera is offline
Default 421 Block - Sevice Replacement?
A friend just bought a 1964 421 block, standard bore,. Faint code on the front. He was wondering if it’s an SR block. Either way, it’s a cool score. Pics below:
ID:	632806   Click image for larger version
ID:	632807   Click image for larger version
ID:	632808   Click image for larger version
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
Old 04-28-2024, 05:59 PM
grivera's Avatar
More
ID:	632810   Click image for larger version
ID:	632812   Click image for larger version
ID:	632813   Click image for larger version
Will Rivera
Old 04-28-2024, 06:04 PM
steve25 steve25 is online now
Real nice!
Dare I ask how much he payed for it?
Old 04-28-2024, 06:10 PM
grivera's Avatar
He’s keeping that private for now…
Will Rivera
Old 04-28-2024, 07:06 PM
johnta1 johnta1 is online now
Service Replacement wouldn't have an eun on it
What's the engine code for it?
Old 04-28-2024, 07:32 PM
grivera's Avatar
He says it isn’t legible
Will Rivera
Old 04-29-2024, 05:53 AM
Just note the ALL service replacement blocks came with rings and fitted Pistons .
Old 04-29-2024, 06:51 AM
grivera's Avatar
Good to know- assembled?
Will Rivera
Old 04-29-2024, 07:39 AM
Mr Twister's Avatar
IMO a freshly shot peened used block. Nice find though.
The Following User Says Thank You to Mr Twister For This Useful Post:
Old 04-29-2024, 08:56 AM
Yes, the rings where on the pistons and the pistons where in the bore.
Old 04-29-2024, 04:06 PM
Dragncar Dragncar is offline
The front 2 four bolt caps are missing the outer bolts.
Old 04-29-2024, 04:47 PM
I never realized that the 64 motors did not use a full length windage tray and still had the bell housing reinforcement ribs from the 425 trophy motors.
Old 04-29-2024, 05:22 PM
1965 engines were the first to use the full length windage tray, the dipstick tube configuration changed completely as well.
Maybe you missed this thread on 1964 389 and 421 blocks:
https://forums.maxperformanceinc.com...d.php?t=772995
And my 1964 421 HO build, both threads show the windage tray setup used on 1964 and earlier engines:
https://forums.maxperformanceinc.com...d.php?t=771741
Old 04-29-2024, 06:02 PM
It’s been a loooong time, but I had a 389 425 T block for a while and just forgot about the windage tray deal.
Old 04-29-2024, 06:09 PM
tom s tom s is offline
for sure 64 block,has provision for block mounted starter.JMHO,worth the same as any std bore 3 1/4 main 4 bolt block UNLESS you need a SR or numbers matching code or vin to a car you might own.Nice clean block.Tom
Old 04-29-2024, 07:50 PM
grivera's Avatar
That was my thought as well, based on pics
Crank too? Short block?
Yep- saw that. Hopefully they are the caps original to the block
Will Rivera
Old 04-29-2024, 08:55 PM
I think the correct term was "fitted block"no crank or rods.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 04-30-2024, 06:00 AM
Xs 2 with the above.
Sorry I should have been more detailed.
Old 04-30-2024, 07:58 AM
grivera's Avatar
All great info - will pass onto my friend
Will Rivera
