Old 11-04-2022, 10:23 AM
TOPHER TOPHER is offline
Default 66 A body Radio and speaker wiring diagrams?
I've been cruising around the web, checking all the service manuals for '66 GTO (including the laminate), and for the life of me, I cannot find any wiring diagram supplement covering the radio and speakers. Anyone have either a diagram or something to show color, connections, etc?
Old 11-04-2022, 10:28 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I checked my '67 Cutlass FSM - it only shows power and ground to the radio. Sorry...
Mike
Old 11-04-2022, 10:39 AM
Maybe M&H can supply me with something...
Old 11-07-2022, 07:09 AM
Jeff Hamlin's Avatar
Not sure what exactly you're after but here are the basic connections for '66-'67.
BLACK-GROUND.
GREEN-SPEAKER.
YELLOW-12V ACC POWER.
The factory dash hardness has the male connector for plug-and-play installs.
Are you missing this?
Hope this helps.
Name:	66-67 RADIO CONN 2.jpg
ID:	601821   Click image for larger version
Name:	66-67 RADIO CONN 1a.jpg
ID:	601824   Click image for larger version
Name:	66-67 RADIO CONN 3.jpg
ID:	601825   Click image for larger version
Name:	66-67 RADIO CONN 1.jpg
Old 11-07-2022, 01:47 PM
That's awesome, thank you!
Old 11-07-2022, 02:16 PM
Kenth's Avatar
Kenth Kenth is offline
You will find all needed info regarding radio in 1966 Tempest Service Manual Section 15 (Accessories).
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-08-2022, 08:56 PM
GT182's Avatar
GT182 GT182 is offline
Do you have an AM or FM radio? Connections might be different. And If you get yours hooked up and have no sound or just a buzzing from it, you will most likely need a new speaker.
That's why I added a modern Kenwood with a USB plug under the dash. It's stereo and I download music (MP3s) to play. Works great and cheaper than buying a converted GM Pontiac AM/FM to replace your AM. Don't cut up your dash to add any other radio but the Pontiac originals. If you do, you will be very sorry later on. I know many that did that years ago and most are still sorry, but a majority that did have replaced their dash.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-09-2022, 08:02 AM
I agree with the OP the SM has very limited info.
As far as connections the color code on the wiring is the same regardless.
Old 11-09-2022, 12:24 PM
Kenth's Avatar
There is 9 full pages, 15-2 to 15-11, of information in the service manual on all aspects regarding radio installation. This is all but limited info.
JMHO
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
