Old 09-10-2020, 02:24 AM
hutchwareltd's Avatar
hutchwareltd hutchwareltd is offline
Default Rear quarter rocker trim installation
My '67 GTO rear quarters behind the wheels needed some panel work (typical). I am test fitting all the rocker trim to make sure it fits well and that I have all the mounting brackets/holes. The repaired quarters don't have any holes for the trim mounting. The bottom obviously just screws in, but how is the top held in place? Are there clips needed or were the small studs used? A photo of the rear quarter behind the wheel with the trim removed would be most helpful Thanks as always for the great support!.
Old 09-10-2020, 07:42 AM
gtospieg gtospieg is offline
I don't have pics but pretty sure the factory had studs. Ames sells small screw in studs for the windshield that would probably work for the quarters. (G134G) in the Ames catalog under windshield moldings.
Old 09-12-2020, 01:58 PM
jhnichols2 jhnichols2 is offline
Here are a few pictures of my 67. I used some small screw in studs available through Fastenal.
Name:	67 GTO RH lower quarter 1.jpg
ID:	549320   Click image for larger version
Name:	67 GTO LH lower quarter 3.jpg
ID:	549321   Click image for larger version
Name:	67 GTO LH lower quarter 7.jpg
ID:	549322   Click image for larger version
Name:	67 GTO LH lower quarter 6.jpg
Old 09-13-2020, 12:18 AM
Perfect - thanks. Now all I have to do is find the clips :-)
