Old 05-23-2022, 12:57 PM
JLuger's Avatar
JLuger JLuger is offline
Default Cold Case radiators
Shout out to cold case radiators I put one in my 66 over the winter couldn’t be happier. Had it out a few times over the weekend temps 85-90 and I wasn’t easy on it.
The Following User Says Thank You to JLuger For This Useful Post:
Old 05-23-2022, 05:09 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Cold case
Very happy with mine as well.
Running good stable temp.
Very well made.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
Old 05-23-2022, 09:59 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Me too. First thing I did on my car was to drop in the Antarctic package. Cold case rad, flowkooler clearanced, 160 tstat, clutch fan. Won’t get above 190 in 95 degree weather idling in traffic. Otherwise it’s 160 all day long.
The Following User Says Thank You to MidnightAuto For This Useful Post:
Old 05-25-2022, 12:44 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Pretty much my exact setup, too, on my 1979 T/A, tho my clutch fan is heavy duty and I also used weatherstrip to seal the shroud to the rad. My needle struggles to even pass the first "peg" on the temp gauge (which is between 100 and 220, so 160)... after an hour drive, I can grip my hand around and just hold my upper radiator hose as long as I want without getting burned or hurt. May be running too cool now, tbh. Cold case, for the win.
And mind you, this was even with a massive exhaust restriction (found out recently that my heat riser valve was welded closed for some reason by a PO) - would explain the huge exhaust leak im still in the process of fixing as of a month now (broken bolts and I refuse to pull the head).
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
Old 05-25-2022, 07:46 AM
JLuger's Avatar
I’m running a pretty mild 455 with a stock water pump with stock fan and clutch setup also sealed up the shroud. Good to go.
Old 05-25-2022, 10:07 AM
5th TA 5th TA is offline
In late 2020 I pulled the stock 301 out of my 1980 TA and replaced it with a Butler 461. The 301 had a small two core radiator, I replaced it with a cold Cold Case radiator and couldn’t be happier. I have a 180 degree thermostat and my EFI displays has never gone over 185, even in heavy slow moving traffic. I am running the stock 301 fan, clutch and shroud. I should mention I have not charged my AC yet, that will be the real test.
The Following User Says Thank You to 5th TA For This Useful Post:
