Old 04-24-2024, 01:30 PM
llwta76 llwta76 is offline
Default The quality of 2nd gen T/A wheel flare welting
I purchased some of the OER wheel flare welting from Summit racing (daughter gave me a gift cert) a bit ago. Comparing it to the original stuff off my T/A it looks a tad narrower. I'm having a hard time getting it to make good contact with the body panel. Has anyone here tried this stuff for fit ? What results have you had? I know there is more expensive stuff on ebay but don't know how it compares. Thanks for any first hand guidance. Larry
Old 04-24-2024, 01:40 PM
PAUL K's Avatar
PAUL K PAUL K is offline
There is a guy here that makes fantastic lacing and it comes in several colors. I believe his user name is Wizard 61. He sells on E-bay and is a great guy to deal with.
Go fast, see Elvis!
Old 04-24-2024, 02:51 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
The 'molded in color' welting is much easier to work with;
https://forums.maxperformanceinc.com...d.php?t=787665
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
The Following User Says Thank You to pontiacstogo For This Useful Post:
Old 04-25-2024, 09:35 AM
78w72 78w72 is offline
Ive used the grey color welting sold by the foot from ames, looks factory correct and is very flexible & easy to install.
Old 04-25-2024, 02:18 PM
bhill86's Avatar
bhill86 bhill86 is offline
The more expensive stuff you’re referring to may be the colored welting referred to above. I recently purchased some and am overall pleased with it and it’s pictured below. There are a few spots it doesn’t sit perfectly against the body which may be due to the back side of the welting being a bit wide. It’s hard to explain and I don’t have any pictures of the back side but it could likely be managed if needed by trimming a bit and “rolling” the welting toward the body. As for the look, I feel like it’s worth the price.
1977 Trans Am 400/4speed (swap)
Brian
