BG 280 Fuel Pump/Regulator Pressure
Hi and ongoing fuel pressure problem with BG280 system. BG 280 pump and 2 port regulator always has high/varying pressure up to 16lbs even After replacing both with New while BG rebuilt originals (welcome to BG world). I try to set @9lbs but will never stay there, checked with shop gauge (not dash) and has New BG filter and line is clear/fuel cell is vented/constant voltage-amps to pump. Called BG tech and they said just send all back again! My other cars have BG400 pumps no problems but they have Return Line unlike 280. Confused
I've had really good luck with the BG 280's. I suspect a regulator problem, maybe a hose coming appart internally after the filter?
We really need to know all about the entire fuel system to understand where there may be issues.
Things like how and where the regulators are mounted can have an affect on this. Line sizes and plumbing before and after the pump can too. Is this regulator dead headed (sounds like it to me). What sorta gauges are you using to get these readings. BG says those pumps are pre-set for 20 psi bypass (internal) from the factory. Are you setting the regulator in a flowing state? The more you tell us the better. |
I ran into the same problem with a 140gph pump "dead-headed" to a billet two port regulator. I ran it for almost two years constantly adjusting the fuel pressure. Finally the pump decided it wasn't going to relieve pressure via the internal bypass anymore! It would just push full pressure all the time which was way too much pressure for the regulator. When I called Aeromotive to see what happened, I was told any pump pushing over 90 gph @7.0+ lbs should NOT be dead-headed. Any fuel pump over the 90 gph rating, in their opinion, must/should be setup with a return style regulator.
I was a little confused as the pump came with instructions for either fuel system plumbing. I was told these are "Generic" fuel system diagrams not intended for proper plumbing of the fuel system. OK, I pulled it off and installed the Mallory 110 pump for the timing being. In the end, if your running a 280 gph pump, even with an internal bypass, I would never try running it dead-head. Now, you'll need to make sure the internal bypass is operational and re-plumb the car with a return style regulator w/return line. Good luck, JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
i have had the same problem with MANY bg regulators. use it for a paperweight and get a magnafuel regulator. and WHEN that pump starts leaking and you get tired of playing ping-pong with barry grant. get a magnafuel 300 or 500 and have no more problems.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension. 5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos |
Make sure you are setting the pressure at about 2000 RPM, when the fuel is FLOWING
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Are you setting the regulator with the motor running? Also may want to check the id. on the inlet fitting and make sure it measures at least .530 and that it is not so long that it is contacting the internals. Also this fitting must be a straight,no 45 or 90's there.
Thank you, Technical Support Barry Grant, Inc. BG Fuel System, Demon Carburetors, Nitrous Works, Rush Filters www.barrygrant.com |
Maybe I'm lucky but I've never had any issues with BG stuff. I've run the 400's since 1991. I DO prefer a return style set up. It just makes sense it would work better and have less strain than a dead head.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
Great!! I have two BG280's that are leaking and need to be sent back. What ever happened to the good old days when you could rebuild your own pump???? I may be just switching to something else. I don't need issues with returns.....waiting.......lost.... returned..... still leaks... etc. Just going with something else will probably be easier. (not cheaper) |
I use product engineering pumps right now,they are fully rebuildable and rated for continuous duty,serious pumps that's for sure.
Another very good choice is the magnafuel stuff. IIRC product engineering sells seal kits for the BG 280 pumps,check their fuel pump parts section on their website. They also repair certain models of BG pumps and regulators as well. product engineering.com HTH. |
most of the guys on this board and in this hobby are perfectly capable of assembling an engine or a transmission. you think they could not rebuild a fuel pump? is it rocket science? i don't think so.
Thanks for replies and BG Tech sorta says it all (and never fully read my post) - 280 systems suck and I had called BG tech a few times just to hear (after they get an expert!) "we dont know - just send it back" even after both been sent back 2x. I would hope they are losing business over time and will shop for a Magna Fuel or whatever. BG products are Top $$$ and I expect better. I even have to have Spares in case any of the BG400 pumps go! Good that things have changed and there are Other Brands/Competition. And I still prefer a Holley Dominator over a ......
I rebuilt Holley blue pumps all the time for myself and others. Never had an issue. For $75 I didn't expect much from those pumps but they did well for the money. When I pay $300+ for a pump, I expect more. I haven't had good results from either BG280 pump I've bought. Each has lasted just over a year. I bought the second one just because I didn't want to send the first one back to get repaired. Now I have two leaking pumps. Why would I send them back and pay $75-150 for each to be repaired plus shipping and have them last a year again? Just doesn't make sense. I'll be switching to something else. |
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC] http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
BG 2 port + Regulator/BG280 Pump
I have had these on my car for years. Just in the last year though my Fuel pressure has been acting crazy and won't adjust. For awhile, when drive it would drop to zero then to 12 psi , jumping around, and would have to pull over because the motor quit running when its at zero. Lately though it is reading 14 psi and stays there. I try to adjust at the regulator the pressure does not change.
I don't have any leaks though. I have 10an from cell to reg and 6an's to the carb. I also think I am going to switch to something else. The one time I called BG, they said I probably had a dirty filter. New filter did not change anything. Any suggestions? Should I go with magnaflow? Holly? others?
Craig/Spring Tx/79 Transam 462 JBP/ #16 d-ports/3900#'s 7.42 @ 91mph 1/8th /1.60 60' |
