Heater Hose recommendation.
My son and I took the car for a Sunday cruise yesterday. I was about 2 miles from the house, and started smelling coolant/noticed the heat gauge rising fast. Pulled into a parking lot, and my son spotted a hole in the heater hose that runs from the head - right next to the distributor.
I replaced it with some Gates 5/8" rubber fuel line. Do I need to get a fancy pre-molded version, or will this work? What sort of pre-molded do you recommend? It's a 1965 LeMans.
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
Ames sells a molded hose for this. I have always just used an unmolded 5/8 that NAPA sells with no issues.
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.72@112, 1.58/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
The Following User Says Thank You to OCMDGTO For This Useful Post: | ||
Thanks. If you look close at that picture, you can see where it burst behind the sharp bend. It seems like a straight hose could work better - just wanted to see if there is something I wasn't considering.
