Old 01-25-2024, 01:01 PM
Gary H's Avatar
Gary H Gary H is offline
Default 65' GTO or Lemans Radio support brace
I need the support brace that goes between the radio and the bottom of the dash on a 65' GTO. Not sure if other years will work or not.
Old 01-25-2024, 02:29 PM
chrisp chrisp is offline
Easy to make if not wanting to wait for original .
Old 01-25-2024, 05:19 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Gary,
Maybe you already know this but the length/height, plus the bends of this radio support bracket is different between 1965 and 66-67.
I’m not sure of the 64 style.
Hope this helps.
ID:	627195   Click image for larger version
ID:	627196   Click image for larger version
ID:	627197   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 01-26-2024, 09:20 AM
Gary H's Avatar
Originally Posted by 60sstuff View Post
Gary,
Hope this helps.
Thanks for this information. No, I wasn't aware of the differences. Still looking for one!
Old 01-26-2024, 11:46 AM
Old Goat Racer's Avatar
Is the bracket the same for a '65 AM and a AM-FM radio?
Everybody knows somthin.
Nobody knows everything !
Old 01-26-2024, 03:18 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
No. The 65 AM/FM has a slightly longer chassis than the AM only and uses a different bracket.
1969 MPC 64-65 T/6, T/8 9773388 65 T/6,T/8 9781333 (AM-FM)
The 74 MPC no longer lists the 65 AM/FM bracket.
In fact I’m looking for a 65 AM/FM bracket but will most likely bend the AM bracket to fit or fab one up.
Old 01-26-2024, 02:23 PM
BOB VIDAN BOB VIDAN is offline
I have the right bracket. PM with contact and ship to info. Also all the 66/67 brackets I've seen have a part number stamped in them, none of the 64/65 do. AM and AM FM brackets are the same.
Practicing social distancing for 65+ years
Old 01-26-2024, 06:49 PM
Gary H's Avatar
PM sent
Old 01-26-2024, 09:51 PM
Stand corrected on 65 usage, 64 - 3 Deuces is correct.
Old 01-28-2024, 12:49 PM
66/67 AM FM brackets are also different, AM vs AM/FM
