Traction bars
I’m idiot checking myself here. Local track called me yesterday and said they were opening up for private test n tune. (I was on a list). I added sticky tires and subframe connectors at the end of last year.
Long story short I ran out and ordered a set of Lakewood universal traction bars. Ordered from Advance because I could get them next day. It looks to me like these is no chance these fit. They hit the lower shock mounts. Am I looking at this wrong? I know I’ve seen slapped bars on first gen f bodies before. Do they take a different kind? I wanted to add them because I’m a little leery of my 1310 joint. I know wheel hop doesn’t help. I do have some leaf springs clamps laying around. I think I read on here before that you can add a clamp near the forward leaf mount or something like that and it will help? Any truth to that?
I think they look cool
Carburetor building & modification services Servicing the Pontiac community over 25 years |
They would look cool if I could bolt them on lol. Do I need a different type?
Your lower shock mount in your bottom plate?
Usually get T-bars that take the place of lower plate & shock mounts to.
I guess I’ll buy some cal tracks or the like. While I agree that they look cool, I was only buying the slipper bar kind because I could get them in less than 24 hours for cheap.
There should still be Lakewoods that have the built in plate. available. Ideally the front snubber right under the front spring eye.
Should done a little more research first, but I was in a hurry.
As Skip Fix mentioned, the good slapper bars are long enough to put the snubber right under the center of the spring eye, and have a built in plate to replace the factory spring plate. I don't think any other style is of much use as a traction aid. My son's 69 Bird is running a set of the CE slapper bars and they do a credible job.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Just saw your sig and if you are making 600 lb-ft of torque then you may need to go to Cal Tracs or equivalent.
You need CalTracs.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
I think you need an electric pump. That's a stout engine to try and feed with a mechanical. Should be a low 11 120mph 1/4 or low 7 97/98 car
I think you need a fuel pressure gauge to see what is really happening. Dragstrips do funny things to cars g forces create issues not all fuel related.
What is your engine combo convertor gearing and exhaust? I tried to look but never found it. When you say you have a big Holley 950hp to try is it a 80496? They only flow 830cfm but work pretty good.
Yes, clamps help.
Yeah. I also probably need adjustable shocks. New springs in the front, and the put a 1350 joint on the rear of the driveshaft. Oh and my rubber engine mount on the driver side is a ticking time bomb
I’ve had a gasser project that’s robbing resources from the Firebird. But I’ll put down a faster time tomorrow assuming I don’t torpedo something. Last year on hard street tires I ran an 8.6 at 88 mph. I hoping to match the MPH to a more respectable 1/8th ET.
The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
Yes, clamping the front half of the leaves tends to make the front half of the spring act like a lever helping forward bite. Leaving the rear half unclamped allows the spring to still react to compression forces. Try to get 2 clamps on each spring if possible.
A turnbuckle on the LF of the engine going to the frame will stop destruction of the rubber mount and make the car safer. Those 2 bolt 45 degree mounts have a habit of breaking, ask me how I know...................LOL |
Read the old Pontiac racers hand book.
If you take and shim them slapper bars that you have they work great. Those are the same ones I use. I shim the back and the front and try to make them level with the ground. When shimming the car must be on it's own weight. Hope this helps. GT. |
Well I made one run. Ran good until about 400 feet and lost fuel. Good ol mechanical fuel system. I also only have a half tank. I stopped at the closest gas station and they only had 87. Didn’t want to put that in, but now I wish I had added a couple gallons so I knew i was keeping the sump covered on acceleration.
Last year I ran 88, this one I massively improved my 60’ but only 82. I’m going to cool down and try to make one more pass. If the fuel system doesn’t give up on me I really think it has a 7.9 in it.
60 foot isn't too bad for a street car, 1.78 is respectable. I thought you had an in tank pump on that thing with 1/2" lines....?? |
