Need expert engine advice
My engine was in the car when I bought it almost 20 yrs. ago. I have put 21,000+ miles on it. (total on engine 40,000+ miles). I've always had to add race fuel to the 94 octane and back down timing a couple of degrees to stop it from detonating.
With 93 octane, I need to add a little more race fuel. Since I retired, I drive the car a lot more. It's getting expensive.(1 gal of 116 oct. to <7 gals of 93 oct). I have asked a few local (smart) car guys about installing thicker head gaskets, like cometic .066 crushed.( felpro 8518PT are in it now). I am getting mixed answers, and "quench" was mentioned also. NOT sure what quench. From my documentation book, I have a receipt from "G&R Performance" in Babylon, NY., 502 Rutgers Rd. Dated Oct. 1995. This is what's listed: 1- boiled block and installed cam bearings. 2- Milled the block. (I was told it was "0" decked) 3-bore and hone .030 over 4- polish and radius crank 5- clevite main bearings 6- balance assy. 7- miloden rod bolts 8-seal power rings 9- Lunati cam and lifters (230@50 dur. 460 lift). 10- boil and peen #77 heads. NOT ported, bronze guides, stock SS valves. 11- miloden screw in studs 12- heavy duty seal power springs 13- HS 1.5 roller rockers 14- I put on 65' tripower intake and correct carbs 15- stock exhaust manifolds and 2.5" Pypes "X" pipe system Do you think the Cometic gaskets will help or make things worse??? thanks, Dave Cam card |
Im not sure on the gasket thickness curing the detonation issue but I think Cometic gaskets require a certain deck finish to seal properly. Donyou have them on there now?
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
50 RA For the mls gaskets I believe.
#64 or 6x4 heads.
Some guys unshroud the chambers to around 76 cc. Here is a thread you can look thru that talks about that. See post 24.
https://forums.maxperformanceinc.com...=839932&page=2 Combining that and going back with a bit thicker head .050” head gasket would drop the compression about a point. Keeping the quench in that .050” or less range would for sure be better. The newer heads have a different valve inclination angle,the valve reliefs don’t line up to a 389 piston. I think it would work with the cam that is in it, but valve clearance would be fairly tight with it zero decked. |
Plugs look like they are a coupe heat ranges too hot. (Strap burnt nearly down to the base). Hard to tell color sometimes from a photo and not natural sun light, but looks like it is running fairly lean. Too hot of plug will effect the color also.
Sorry for the family health issues. Last edited by Jay S; 12-06-2022 at 10:12 AM. |
The Following User Says Thank You to Jay S For This Useful Post: | ||
2. Who has tuned the carbs, and who has tuned the distributor advance curves--vacuum and centrifugal? What is the initial advance? What is the total timing? Vacuum advance on manifold or ported vacuum? 3. Was the cam "degreed" or merely installed dot-to-dot? 4. What is the cranking compression with a fully-charged battery? What is your elevation? Thicker head gaskets are likely to make things worse unless you go unreasonably thick so as to gain "open" combustion chambers, with a loss of power. I would absolutely not rip the engine apart until I had played with the carbs and distributor, and made sure the cam was in time. Last edited by Schurkey; 11-02-2022 at 12:47 PM. |
The Following 2 Users Say Thank You to Schurkey For This Useful Post: | ||
How far down in the hole are your pistons?
A .060 Gasket only leaves you a few thousands before you wander into high probability of combustion issues and detonation. A .040 gasket would be better. Tom V.
What cid is this engine? Is it still a 389 under the #77 heads?
Your short bio indicates you are in PA. I believe there is fairly wide adoption of e85 at the pump in many areas of PA. This could be a decent solution for you that doesn't require taking the heads off. I dealt with this exact same issue in my bird. Purchased the car with the engine already in it and it pinged even on 100 octane fuel @ 7.52/gallon. I ended up going through the entire top end and replaced the heads with KRE D ports and went to a larger roller cam. That solved the issue and gave me a good bit more power to boot. However it was an expensive proposition in itself. E85 would provide the knock resistance necessary for your combination. You'd need to set up your fuel system to handle the added fuel requirements and ability to handle E85. If you're still running a carb, that would need modified to provide proper fuel metering as well. It would however be more budget friendly then swapping heads. I will say this, if you're going to go to the point of taking the heads off, I wouldn't bother with thicker head gaskets. There's real possibility, depending on how far in the hole your pistons are that loss of quench distance may exacerbate your problem. If the heads come off, measure your piston to deck height, determine proper head gasket thickness to achieve around .040 quench distance, then choose a head to go on the engine that will achieve around 9.3:1 compression if you're staying with a factory iron head, or around 10:1 compression if you're going to a modern combustion chamber aluminum head. If you're going to that trouble, make sure you solve the problem for good. One thing to consider is that going to a later style head may require a number of changes that could include changing the intake manifold or even changing pistons depending on the type installed and how much net valve lift you have. With your older closed chamber heads, I would lay odd you have the 8 valve relief pistons in that engine, which may be contributing to the problem. They would however allow you to move to a later head without worrying much above piston to valve clearance.
How big is the engine? What's the compression ratio.
At a quick glance I'm not so certain the camshaft is doing you any favors as far as cylinder pressures are concerned. Thick head gaskets aren't really going to help the issue, actually that may likely make matters worse. Cam install position is a big player. Lots of other small things factor in, carb, distributor, heat, etc... Need more info |
You have a lot more fuel and air entering the cylinders with that cam, but the exh side of all the street production 326/389 and 421 heads just plain sucks!
The motor can not pump the burnt gasses out efficiently and if your making the mistake of retarding your distributor timing, then that helps the pinging situation out at low speed, but makes things worse during heavy throttle since the motor was relying on cylinder pressure too much to pump out the exhaust thru those stock restrictive ports. I have seen this countless times over the decades with these heads ! I also guarantee your carbs are too lean with that cam now in the motor. Your jetting on the center carb needs to go up to .068” to .070” and the end carbs need to go up to .070”. And this is for starters! What do your plugs look like ? Take some side photos of the ground electrode on 4 of the plugs and post them up. What does the motors hot cranking compression check in at?
I do stuff for reasons. Last edited by 25stevem; 11-02-2022 at 03:43 PM. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
My engine is a 1966 389cu in. that has been bored and honed .030 over.
Stock 1965 #77 heads. Harland Sharp 1.5 roller rockers, heavy duty springs. Felpro #8518 gaskets in the car currently. They are Flat top pistons. Was told they are zero(flush with deck. Not sure Carbs are tuned with cam in mind. Car does run real good Was told by previous owner compression is near 11:1. I have no way to know for sure. All this is above my paygrade. I am NOT a mechanic. I can take anything apart and put back together, but I do not know what makes the internals of an engine perform perfectly. Thanks guys for your time |
The .060” Cometic head gasket would not change the static compression enough to be worth the time, it might even run worse.
I think it would take a minimum of a .090” thick Cometic to have any success. Probably about .1” would work the best, then use cometic’s thick intake gaskets to line the intake back up. I have an engine that runs .14” thick Cometics, and another that has .075”. |
Has your distributor been built for your combo?
Was your carb dialed in with a wideband? How hot does you car run?.. ever get over 190 degrees? Are your exhaust crossovers active?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
The Following User Says Thank You to shaker455 For This Useful Post: | ||
[QUOTE=shaker455;6384233]Has your distributor been built for your combo?
Was your carb dialed in with a wideband? How hot does you car run?.. ever get over 190 degrees? Are your exhaust crossovers active?[/QUOTE 1- stock dizzy with Pertronix ignition. 2- correct tripower carbs., bigger than stock jets and opened venturi tubes slightly. 1/4" phenolic spacers on all three. Adjusted with vacuum gage. 3-Only runs above 190 when on the highway driving over 60mph. will get to 205degrees. Rear gear is 3:90 with NO overdrive. ,4sp Muncie. 4- crossovers are not blocked. Car will stay under 190 degrees all day long around town ,even in traffic in 90degree weather. |
[QUOTE=dhcarguy;6384264]
Initial timing Degrees of Mech advance amount of vacuum advance and ported or non ported source? Total timing Also, I would not exceed .050" on head gasket swap as proper quench will be diminished. High CR can live on the street but tuning has to be right on Depending on your pistons a small D-shaped dish can be machined in to get you lower CR and maintain proper quench.
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 11-02-2022 at 08:11 PM. |
All things being equal, if all is properly tuned why don't you switch to the proper cc heads. Aluminums would be nice.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
[QUOTE=shaker455;6384278]
Dave |
The Following User Says Thank You to dhcarguy For This Useful Post: | ||
77 heads on stock motor is 10.75 to 1 I believe.
Engine is Not stock
