Long story short, for a variety of reasons I had my local wrench put on a new set of front brake shoes on my 1968 GTO while he was doing other front end work that I don't have the tools or the time to do. I didn't tell him to turn the drums so of course he didn't and of course I realized they needed turning when I got the car back and drove it a bit. Since I had a few hours today I pulled the drums off and had them turned, but I noticed that he put the brake shoe with the large asbestos pad on the back of the plate facing the rear of the car, and the shoe with the smaller asbestos pad facing the front of the car. It's been a long time (30+ years) since I did drum brakes, but intuitively this doesn't seem correct to me. Can anyone tell me if in fact this is the proper way to install the front brake shoes? I'd like to have an expert opinion before I take it back to him. FYI, with the turned drums on it the car stops fine now.
Thanks! |
CORRECT. Large shoe goes to rear of car, because it is the first to make contact with the drum as you apply the brakes in the forward motion of the car therefore having the most wear of the two shoes.
Charles |
Old Goat, (I can relate to that...) thanks for your reply. I'll enjoy my newly found stopping power worry-free.
Sounds nasty but and old shop teacher told us to think of prison when working on drum brakes- the shoe that is longer, harder and darker goes in the rear. :-0
![]() Quote:
![]() Quote:
FWIW, the rear shoe does all the work. |
![]() Quote:
So what happens if you get this backwards? What symptoms would you expect to notice when braking?
Terry Hunt "He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr. |
Primary shoe mis-installed in the secondary position? Excess wear of the short, soft, white shoe. I don't remember what the braking performance is like--perhaps grabby brakes.
Ouch!
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
bad visual, bad visual *repeats to self in futile attempt to erase memory*.
Just remember this applies to Bendix style brake systems. The leading/trailing design (pretty much used in most applications today) is the opposite.....bigger shoe goes up front.
landed on this old thread doing a quick search as I was trying to remember shoe direction.
Decided to grab the 68 service manual to confirm & Interestingly it shows the longer primary shoe towards the front of the car. Hmmmm Seems odd, Different type of shoe though looking at the picture. '
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA Last edited by 68ragtop; 05-27-2018 at 02:51 PM. |
![]() Quote:
The secondary shoe would get the park brake lever, and be towards the rear. However, I'd expect it to have the longer, thinner, harder darker-colored lining material. The primary would get the shorter, thicker, softer, lighter-colored lining material. |
Yep. X2 with shurkey
The primary shoe is the shorter length of friction material The secondary is the longer length of friction material Also, the "Strut " they have pictured is what I refer to as the "reaction rod" for the parking brake. |
From 67 Shop manual, Page 5-9;
NOTE: When replacing shoes, always be certain to assemble secondary shoes to the rear and pri- mary shoes to the front. Note that linings of pri- mary shoes are usually shorter than secondary linings. |
Intersting picture for sure. Makes me wonder how many got installed backwards because of this picture. Mine almost did.
![]() Also, I noticed they have the strut shown backwards as well. No way its installing in that direction.
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
