Where to get Qjet
Im looking for a good Qjet carb.where is the place to get one.I have no core.
Go to each U-Pull-it in your area, and pick ANY non-electronic Q-JET you come across. Be sure to figure the vehicle arrived JUNK for some other reason. Run Q-JET as-is except to put Accel Pump rod on inner hole & put your preferred Sec Rods in. $35.
oh, you're welcome. |
check junk yards, craigs list, ebay......according to the literature by Ruggles the best carbs rank in the following order.
1. 73'-74' super duty Pontiac (big bucks for one) 2. 71'-74' Buick carbs that came on 455s (reasonably priced) 3. 71'-Pontiac 455 HO carb,( no outer booster ring and ridiculously priced) 4. I would look for anything produced between 1975-80, they are cheap,plentiful, and are very capable performers. Stay away from the computer command control (CCC) ones. I also highly suggest getting the Cliff Ruggles book on Q-jets. I learned quite a bit from it. I had a 400 w/ (13) heads,ran great with a Q-jet. However I sold the car and now Building a 455 stroker engine (501) with the parts supplied from Bulter Performance. The engine came with a 850 DP Holley so now I'm trying to learn and acquire as much info as I can about those.......good luck on the search. |
Post in the parts wanted section here is a good start.Tom
Ebay is swimming in quadrajets. You just have to know how to spot a good core. I wouldn't pay more than $75-100 for a good core. I paid $57 for a nice '80 model from a 350 camaro.
This could be a really good core, it's just got the chevy fuel inlet. http://www.ebay.com/itm/ROCHESTER-QU...f56e78&vxp=mtr
Q-jet
I had better luck at the swap meets then I did with E-bay.
The core I sent to Cliff was from a freind who had an extra that was complete and the exact style I needed. Pay close attn to choke, throttle linkage and vents Good Luck and Good hunting GerryC
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
What kind of Quadrajet are you looking for. I have several rebuildable cores. PM me if you still need one.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Ditto - I have several as well...
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
If you are patient you can still find complete unmolested Q-jets on Criagslist for $5-10. I have a shelf full. Sometimes people just want to get rid of them.
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
I recently bought a core on idiot-bay for $30 shipped to my door. I sunk about another $100 bucks in parts into it, and rebuilt according to Cliff's book. Carb works flawlessly, and I'm into it for about $125 plus my time.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
I've worked on a boat load of, them. I've got most of the drill bits needed, waiting on the smallest set. Then will get some goodies from Cliff........Looking forward to putting the "Cliff' tune on one... If I don't spend money on ANYTHING else, I'm doing this, this year!!! Don't dismiss a Chevy inlet carb (if you would WANT to use one, that is) I'm running across ton of 17050204 Chevy carbs. THey are 750 CFM units w/ APT, still a good carb to use (I think???)
Send me an email Jeff
Carburetor building & modification services Servicing the Pontiac community over 25 years |
